It is currently Mon Apr 20, 2015 10:20 pm
 Post subject: New Laptop CPU
PostPosted: Mon Apr 08, 2013 10:49 am
I have a laptop with a AMD Sempron 3500+, and was curious if this CPU would work in it?
http://www.ebay.com/itm/AMD-Turion-64-X ... 1c315efcbd
and can it be upgraded to 4GB of DDR2? I have 2GB in it right now. I want to upgrade this computer because I use it all the time for stuff like internet, music and Skype while gaming on my desktop and would like to have a little more speed. Also... are there any IDE SSD's? Like a 120GB? Just curious, might get one if they're cheapish. Oh and are there any keyboards that would fit it that have a back light? Thanks! :D
 Post subject: Re: New Laptop CPU
PostPosted: Mon Apr 08, 2013 12:17 pm
I can tell you...
  • Yes you can use the CPU, it's socket compatible. But it has a higher TDP, your laptop may not be able to cool it sufficiently.
  • Yes you can upgrade to 4GB
  • No there are no IDE SSDs (IDE is too slow anyway)
  • No there are no backlit keyboards for your laptop.
Please use Google/Bing/Yahoo/Ask next time.
PostPosted: Mon Apr 08, 2013 3:02 pm
OK! Thanks! I'll try using Google more.
Off topic(ish), I tried Googling it but found nothing. I am using a GTX 580 3072MB and I have a 2048MB GT 440. I was curious would I gain FPS if I used the 440 for CUDA? Or would it not help? Also I was gonna use the 440 in a desktop I built but it had a bad PSU and had a power overload. So I am not 100% sure if it works, plus I never used it before then. Thanks! :D
PostPosted: Wed Apr 10, 2013 6:21 am
Umm... CUDA is the name for Nvidia's GPU compute technology. It has NOTHING to do with gaming. If you're referring to PhysX then yes, you can use the other card as a PhysX processor. Keep in mind that you need to use up to date drivers and the game has to support PhysX specifically or you'll see no advantage to this setup.
