It is currently Wed Jan 28, 2015 2:45 am
 Post subject: Building a new PC, need a review!
PostPosted: Mon Apr 08, 2013 10:21 pm
So I have decided to build my first PC, I am semi-new to it. I have assisted in build or 2 but never one of my own and I am looking for some info to see if everything is in order. I am intending to try and stay under the $600 mark but if need be I will put extra in.
This PC is for the most part intended for gaming and the goal is to have it running modern games at high settings with 60+ FPS without going too extreme on the cost.
The current parts I am most likely going to go with:
http://pcpartpicker.com/p/PG6M (Previous link: http://pcpartpicker.com/p/Ps3k )
I have all of the other bits and pieces necessary already (cords, DVD Drive, Monitor).
I already have a Sandisk SDSSDX-240G-G25 for my main storage/boot up drive. In the future I will add a 500GB or 1TB HDD for extra space, I also already have the OS I am going to install.
So let me know what you think and please point out any faults and try to be brutally honest with what I can improve on.
EDIT:
-Updated Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply - $40
-Updated CPU: AMD FX-4300 3.8GHz Quad-Core Processor + $5
-Updated GPU: Zotac GeForce GTX 650 Ti 2GB Video Card + $5
+ If I decide to do some overclocking (which I most likely will within the year) will this case be suitable for keeping it repetitively cool? If not please suggest a better case that isn't too expensive, or if I should add a different CPU Cooler.
 Post subject: Re: Building a new PC, need a review!
PostPosted: Tue Apr 09, 2013 6:54 am
Get this power supply instead http://www.newegg.com/Product/Product.a ... 6817139027 and spend the $40 on something else :D
PostPosted: Tue Apr 09, 2013 8:04 am
Good coice; don't need that extra wattage for this build. Maybe use the extra $$ for Windows
PostPosted: Tue Apr 09, 2013 10:07 pm
Thanks for the input! :D
-Edited OP
