It is currently Mon Apr 27, 2015 4:48 pm
 Post subject: Inexpensive Backlit Keyboard?
PostPosted: Sat Apr 06, 2013 7:25 pm
Looking for cheap backlit keyboard. I have a music studio and the light is ultra-dim. I have no need for 'gaming' functions of any kind. I bought an 'Azio' backlit kb from Newegg for $25 which is fantastic, -except- that the tactile feel is seriously the worst I have ever experienced in a PC keyboard. It literally has -zero- feedback, let alone 'click'. It's hard to tell if you've accidentally hit a key or not.
All the other backlit kbs I've seen are in the $100 range and seem to be mechanical... which is great, but I can't see spending that kind of money. I just need a 'normal' non-clicky wired 101 keyboard, but hopefully with backlight.
Any ideas?
TIA,
---JC
PS: I'm no gamer but I find the mag very useful for our studio,
 Post subject: Re: Inexpensive Backlit Keyboard?
PostPosted: Sat Apr 06, 2013 9:10 pm
I've got the Logitech K800 Illuminated wireless board, but I know they do have a wired version of it for less, same keys, I like it a lot. It's not mechanical but the backlighting is decent, variable brightness as well. not sure what the wired version costs offhand but I'm sure you can find it,.
nbrowser
PostPosted: Sat Apr 06, 2013 9:17 pm
AZIO Large Print Tri-Color Illuminated Keyboard KB505U Black 104 Normal Keys USB Wired Ergonomic Keyboard ($28.99). The cheapest one the Egg had.
PostPosted: Sat Apr 06, 2013 10:03 pm
Yeah, this is the one I have. Like I said... looks great. Feels AWFUL.
PostPosted: Sat Apr 06, 2013 10:31 pm
Backlighting is just something seen as a premium option these days. So... You could either get the next more expensive thing or bite the bullet. Something like the Logitech Illuminated wired goes for $80 or so. The only problem is that I have a feeling they did another revision, because people were complaining about key ghosting and the one I have doesn't have ghosting issues as described.
So for gaming... might not be the best choice
PostPosted: Sat Apr 06, 2013 10:35 pm
Monkey Federation (Top 10)
This is what I use and like it:
http://www.amazon.com/Saitek-Eclipse-Ba ... B000H6AY6M
PostPosted: Sat Apr 06, 2013 10:41 pm
idaiki wrote:
Thanks. Seems reasonable. I also stumbled on this: http://www.amazon.com/gp/product/B005S0 ... UPJ4C2HX16
I don't care about the 'Call Of Duty' thing at all, so long as it works.
Cheers for that.
---JC
