It is currently Tue Apr 28, 2015 10:45 am
 Post subject: AMD A8-5600K build question.
PostPosted: Sat Mar 16, 2013 12:56 am
I am planning a build with:
HEC ITX 200B htpc case: http://www.tigerdirect.com/applications ... =H702-0006
500GB HDD: http://www.tigerdirect.com/applications ... SD-500AZEX
AMD A8-5600K apu: http://www.tigerdirect.com/applications ... u=A79-5600
8GB 1866MHz DDR3: http://www.tigerdirect.com/applications ... u=C13-5704
ITX FM2 motherboard: http://www.tigerdirect.com/applications ... YAP-132106
What I would like to know is, is the 200 watt power supply that already comes with the htpc case sufficient enough to power all of that along with a slim dvd-rom drive that I already have? I have a budget of about $450 and don't really need dedicated graphics as I understand that the A8-5600K plays games very well at 1280x720 resolutions (32" Haier 720p hdtv). Thanks in advance.
 Post subject: Re: AMD A8-5600K build question.
PostPosted: Sat Mar 16, 2013 9:25 am
Yes, it should be plenty to power the system.
PostPosted: Sat Mar 16, 2013 3:38 pm
Thanks Latios.... that's a load off my mind. Good to know that it'll be good enough to power the system. Thanks again!
