It is currently Sat Apr 25, 2015 12:54 pm
 Post subject: Asus P8Z77-V Deluxe (Best way to use 2 x SATA 6Gb/s port)
PostPosted: Wed Feb 27, 2013 1:39 pm
Not sure how to use the to cache ports. How exactly do they cache. Can I select programs I want to cache.
Also I want to load my operating system, windows 8 and all program such as Office and more, onto a "0" Raid. Here is my plane:
1. "0" Raid 2-OCZ 120gb each (Operating system and all programs).
2. "0" Raid 2-OCZ 250gb each (Working Drive) Files moved as needed to drive, when done saved to BackUp Drive.
3. OCZ 500gb Most resent support files ( Files mostly used with above drive 2.
4. 2 Drives Seagate Momentus XT STBD750100 750GB
5. 1 Drive TOSHIBA DT01ACA300 3TB 7200 RPM SATA 6.0Gb
6. USB 3 CoolMaster Storm Trooper - Front Case needs a USB3 contention
7. SSD CoolMaster Storm Trooper - Front Case needs a SSD contention
The board is a Asus P8Z77-V Deluxe. Not a clue as the best approach for drive orientation. I have every thing installed. But I'm on hold while I try to figure a good plane.
Bob
 Post subject: Re: Asus P8Z77-V Deluxe (Best way to use 2 x SATA 6Gb/s port
PostPosted: Wed Feb 27, 2013 1:57 pm
Caching on most of these systems is dependent on an algorithm, which is usually something FIFO style. That is, when you set up SSD caching (which is something you RTFM to do), you won't see a performance benefit until the things you want cached are used frequently.
PostPosted: Wed Feb 27, 2013 4:10 pm
Thank you. This is the info I needed. Let me take some time and till you how I will use my data. I have replays to this guess from people more concerned on all the drives. But you are giving me some think that has sustenance. I have to think how I use my data, does it repeat. Thank you so munch.
I want to think this out before I respond.
Bob
