It is currently Mon May 20, 2013 6:47 am
 Post subject: Build Help? UPDATE!
PostPosted: Tue Feb 12, 2013 2:03 pm
Hello All,
I'm getting ready to order/build me a new system (below) & have a couple of questions.
I'm going to be re-using a couple of the parts from my current system (case, power supply & Western Digital VelociRaptor 300GB) & just wanted to know what SATA ports I should use?
When hooking up the optical drive (ASUS DRW-24B1ST DVD Burner) & HDD (WD Velociraptor WD300GLFS-01F8U) I use the SATA II 3Gb/s ports correct?
It's been several years since I've built my last system & some things have changed.. I just want to make sure I do it right!
Thank's, Phil B.
New System Specs:
Processor: Intel Core i5-3570K.
Motherboard: MSI Z77MA-G45.
SSD: OCZ Vertex 4 256GB= Winows 7 64-bit.
HDD: Western Digital VelociRaptor 300GB= Storage.
Memory: Crucial Ballistix Tactical 8GB (2 x 4GB) DDR3 1600 (PC3 12800) Low Profile.
Graphics: EVGA SuperClocked GeForce GTX 660 2GB.
Optical Drive: ASUS DRW-24B1ST DVD Burner.
Power Supply: CORSAIR TX650W.
Case: Cooler Master HAF 922.
Current System:
OS: Windows 7 HP 64-bit
Motherboard: EVGA 680i SLI A2 122-CK-NF68
CPU: Intel Core 2 Duo E6600 2.40GHz.
Graphics Card: EVGA 8800GTS 640MB.
Hard Drive(s): System: Western Digital VelociRaptor 300GB
Memory: OCZ 2x512 & 2x1GB Gold GX XTC PC2-6400.
 Post subject: Re: Build Help?
PostPosted: Tue Feb 12, 2013 2:08 pm
It doesn't matter which, but SSDs should have the 6Gbps ports.
Also make sure they're the ones that go into the chipset. I have a motherboard that has two 6Gpbs ports, but it's not part of the chipset so it's performance is more like 3Gbps.
 Post subject: Re: Build Help? UPDATE!
PostPosted: Sat Feb 16, 2013 12:30 am
Hello All,
Just wanted to thank everyone for there help & let you know I ordered my new system on Thursday & it's on the way & will be here Monday, I'm so excited!
I'll upload some pics when it gets here & take some as I re-build the system.
Later, Phil B.
New System Specs:
Processor: Intel Core i5-3570K. NEW.
Motherboard: MSI Z77MA-G45. NEW.
SSD: OS Drive= OCZ Vertex 4 256GB: Windows 7 64-bit. "NEW"= Black Friday Deal.
HDD: Storage= Western Digital VelociRaptor 300GB. Re-Used.
Memory: Crucial Ballistix Tactical 8GB (2 x 4GB) DDR3 1600 (PC3 12800) Low Profile. NEW.
Graphics: EVGA SuperClocked GeForce GTX 660 2GB. NEW.
Sound: Creative Sound Blaster X-Fi Titanium. Re-Used.
Optical Drive: ASUS DRW-24B1ST DVD Burner. NEW.
Power Supply: CORSAIR TX650W. Re-Used.
Case: Cooler Master HAF 922. Re-Used.
Current System:
