It is currently Fri May 24, 2013 2:57 am
 Post subject: GPU Question
PostPosted: Sun Feb 10, 2013 10:12 pm
I'm planning on getting an EVGA GTX 660 in a month or so. I cant really afford to spend more than 250, but i'd like to stay as close to 200 as possible on it and i was curious if AMD had a better offering for the price.
On a side note my PSU only has one 6-pin connector
 Post subject: Re: GPU Question
PostPosted: Sun Feb 10, 2013 10:47 pm
The Radeon HD 7850 2GB runs close to $200, though I'm not sure if this comparison is up to date with the drivers. So it might actually perform only slightly worse.
And it only requires 1 6-pin PCI-Express plug
PostPosted: Sun Feb 10, 2013 10:56 pm
ok after looking around a bit more another question comes. would the 7870 be better than the 7850 as far as price/performance goes.
PostPosted: Sun Feb 10, 2013 11:02 pm
Considering you can get one as low as $230, yes.
PostPosted: Sun Feb 10, 2013 11:06 pm
im looking on newegg and found them but i notice the 7870's need two 6 pin connectors, but it looks like they come with and adapter for a 4 pin
SAPPHIRE 100354OC-2L Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card
