It is currently Mon Mar 30, 2015 2:50 am
 Post subject: I'm a first time build. what do I look for?
PostPosted: Mon Feb 04, 2013 7:51 am
I'll start with the basics. I'm new to gaming PC. Haven't built one yet, but looking to play games like Skyrim, Elder Scrolls Online, Shooters like Battle Field, etc. Budget around 700-800.
When looking into GPU's and CPU's, What exactly are you looking at to determine whats better than the other one?
Also what brand is best to buy over other brands. I read Intel but I also read AMD for the price so I am confused as to which one I get.
If any of you have a budget like I have or did have, could you post up your specs so maybe I can follow the same direction? When I get more time later, I'll go shopping online and post up my possibilities.
Thanks guys.
 Post subject: Re: I'm a first time build. what do I look for?
PostPosted: Mon Feb 04, 2013 10:57 am
When your deciding on a CPU it depends on what types of applications your going to be running aside from gaming that determine what CPU is best for you. Typically Intel is better when it comes to gaming and AMD is pretty good when it comes to heavily threaded tasks like video editing/encoding. You are only gaming from what it sounds like so I would recommend Intel for your computer build. If you are going to play a lot of games that have PhysX support then you'll want to go with an Nvidia video card but Raedeon cards offer very good value at the $130 to $150 price point.
This is my recommended build for you
Corsair Carbide 200R Case $50 http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
Intel i3-3220 Processor $130 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
Heat Sink Stock $0
ASrock Z77 Motherboard $140 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
4GB of Gskill RAM $27 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
Sapphire 7770 GHz edition video card $115 http://www.newegg.com/Product/Product.aspx?Item=N82E16814202011
WD 1TB hard drive $85 http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
Corsair CX430 power supply $45 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Lite-On DVD Burner $17 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Windows 7 Home Premium $100 http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Total $705
PostPosted: Mon Feb 04, 2013 11:06 am
Yes,mainly for gaming. Besides the usual web browsing. Video watching.
PostPosted: Mon Feb 04, 2013 11:09 am
What's the difference between dual core and quad core
PostPosted: Mon Feb 04, 2013 11:18 am
2 vs. 4
Read this and when you come back we can really get down to business.
PostPosted: Mon Feb 04, 2013 11:56 am
Ok I read it.
PostPosted: Mon Feb 04, 2013 3:47 pm
kleinkinstein wrote:
2 vs. 4
I am not computer savvy, but I'm guessing I should go with an i5 or i7 instead of an i3?
PostPosted: Mon Feb 04, 2013 3:53 pm
A Core i3 is fine for video gaming.
PostPosted: Mon Feb 04, 2013 4:01 pm
Do you think an I3 would be good for gaming down the road in about a year? For up to date games like Skyrim with Mods and Elder Scrolls Online, open world games etc.
PostPosted: Mon Feb 04, 2013 4:07 pm
It's probably good for at least 2. Games are often GPU bottlenecked than CPU bottlenecked.
PostPosted: Mon Feb 04, 2013 5:15 pm
Ok and for the graphics card above, you think that's good enough to run skyrim with mods? And look great?
Users browsing this forum: No registered users and 13 guests
