It is currently Sat Apr 25, 2015 6:55 am
 Post subject: RAM question
PostPosted: Tue Jan 29, 2013 6:32 pm
looking for ram was going to get 4GB x 2 for a motherboard im going to buy but want some opinions for this. the mother board has 4 slots 2 ddr2 and 2 ddr3 my old pc uses ddr2 so im getting this MB to utilize the ram i have 2GB X 2 DDR2 i have been shoping for ram and found 1 8 GB
so is it better to have the only reson i ask is bc the one 8 is the cheapest i have found at 1333 mhz 32.50
1 8 GB ddr3
1 2 GB ddr2
blank
1 2 GB ddr2 or
1 4 GB ddr3
1 2 GB ddr2
1 4 GB ddr3
1 2 GB ddr2
 Post subject: Re: RAM question
PostPosted: Tue Jan 29, 2013 7:15 pm
Whooa, hold on Sally! You can't mix ddr2 and ddr3. What is the make/model of your motherboard and what proc are you sporting?
And if your Mom hasn't yet pulled you to the side and told you that capitalization exists for a reason, I will! It's a tool, don't be one, so use it. Capitalization is the difference between helping your uncle jack off a horse and helping your Uncle Jack off a horse.
PostPosted: Tue Jan 29, 2013 7:48 pm
1 8 GB ddr3
1 2 GB ddr2
blank
1 2 GB ddr2 or
1 4 GB ddr3
1 2 GB ddr2
1 4 GB ddr3
1 2 GB ddr2
Well if your old computer uses DDR2, you can swap them out for DDR3s, they are newer and also better. 1 RAM chip will do the same as 2 if they add up to the same (i.e 2 4GB DDR3 and 1 8GB DDR3). You can go for the 1 8GB DDR3 if and it should be fine. You could also go the traditional 2x4GB cards, but why not just 1?
PostPosted: Tue Jan 29, 2013 8:46 pm
Uh. Slots for DDR2 and DDR3 are physically different. You can't upgrade a DDR2 motherboard with DDR3 modules.
PostPosted: Tue Jan 29, 2013 10:03 pm
if its old enough that it uses ddr2, it will not be able to use an 8gig memory chip. probably cannot use a 4gig chip either, and as said above, you cannot use ddr3 in a ddr2 board.unless it's one like this, http://www.tomshardware.com/news/MSi-Eight-Memory-Slots,7214.html but this board came out in 2009. there were other transition boards made that had two slots for each type of memory. gigabyte, asus, and asrock made one.
PostPosted: Wed Jan 30, 2013 7:29 am
Newer and better yes, but physically incompatible.
PostPosted: Wed Jan 30, 2013 3:07 pm
the motherboard has ddr2 and ddr3 slots thats why the question came up. from my understanding the diff between ddr ,2, 3 is voltage thats why the slots are diff so you do not ruin a motherboard so why would it have ddr2 and ddr3 slots if they cannot be used together please pay attention to original post it even says 2 of each slot
Last edited by wolverineweapon on Wed Jan 30, 2013 3:12 pm, edited 1 time in total.
PostPosted: Wed Jan 30, 2013 3:10 pm
here is a link to motherboard http://www.newegg.com/Product/Product.a ... 6813157309
PostPosted: Wed Jan 30, 2013 3:59 pm
If you read the product sheet on the page, you'll find that it says:
Quote:
DR3 and DDR2 are supported separately.
DDR3 memory is only supported by installing AM3/AM3+ CPU.
Meaning, you can't mix and match memory modules of different types.
PostPosted: Wed Jan 30, 2013 4:04 pm
Thank you I completely looked over that I had a motherboard picked out and I saw that one and thought that since I have ddr2 and I'm getting ddr3 I could come out with even more ram but I'm going to go back to the other motherboard that I had picked the CPU is amd 6100 fx am3+
PostPosted: Wed Jan 30, 2013 4:23 pm
A handy utility for checking what RAM you're using is CPUZ. The Memory tab will tell you what type of memory you have as well as the timings.
