It is currently Sun Apr 26, 2015 5:15 am
 Post subject: Build configuration and question about PSU
PostPosted: Mon Jan 28, 2013 2:47 am
Hi,
This is what I configured so far. It is a relatively inexpensive system and I'd like to keep it under $800, which I did (after rebates) from newegg.com. At any rate, I was wondering if a 620w Antec PSU would be enough for this system. Thanks in advance for any help.
Recycling Blu-Ray Drive, Keyboard, Mouse, and Monitor
Intel Core i5-3570K CPU:
http://www.newegg.com/Product/Product.a ... 6819116504
MSI B75MA-E33 LGA 1155 Motherboard:
http://www.newegg.com/Product/Product.a ... 6813130654
PNY Geforce GTX 660 Ti Video Card:
http://www.newegg.com/Product/Product.a ... 6814133466
G.Skill Ripjaws 8GB DDR3 1866 Memory:
http://www.newegg.com/Product/Product.a ... 6820231455
Seagate Barracuda 2TB Hard Drive:
http://www.newegg.com/Product/Product.a ... 6822148834
Antec 620w Power Supply:
http://www.newegg.com/Product/Product.a ... 6817371031
COOLER MASTER HAF 912 ATX Mid-Tower Case:
http://www.newegg.com/Product/Product.a ... 6811119233
Total = $736.91 after rebates
 Post subject: Re: Build configuration and question about PSU
PostPosted: Mon Jan 28, 2013 5:08 am
The eXtreme PSU calc puts you at 306W min / 356W recommended so the 620W is overkill but will work just fine and last through several upgrades (or generations for that matter), it's a killer deal I picked up one of each (a 400w and 620w) myself this weekend too.
The k-series is screaming for some z77 for OC potential, I usually use the b75's for budget i3 or pentium g-series builds. You could, get the non-k series i5 and bump up to an h77 for a more balanced budget build, and for most quads I throw in a cooler like the hyper212 just to keep quiet coolness when the load demands rise.
I am sure there will be other suggestions, cheers mate
PostPosted: Mon Jan 28, 2013 7:56 am
500W-550W is where I would put this build, where under a nominal load the PSU should be floating at its most efficient area. But 600W should be fine. You can even add more powerful hardware down the road if you like.
PostPosted: Tue Jan 29, 2013 10:41 am
Thanks for the suggestions and answer to my question. I'll take them into account.
PostPosted: Tue Jan 29, 2013 10:59 am
Nice build spec. Only tweak would be to upgrade to a Z77 board for native sata III and the current day accoutrements. The Asrock Pro4-M can be had for $60 at Microcenter when you also cart their $190 3550K. Also you don't need to pay for 1866 dimms, snag some 1600 magic ram instead and just crank them up for GBPS delight.
PostPosted: Fri Feb 01, 2013 11:49 am
cpu cooler? looks like a great rig..
