It is currently Sat Apr 25, 2015 10:05 pm
 Post subject: Is this computer from cyberpowerpc worth $3285
PostPosted: Sun Jan 27, 2013 3:27 pm
Im thinking of buying this computer from cyberpowerpc.com, is it worth it? if it is how good of a computer will it be?
*BASE_PRICE: [+1585]
BLUETOOTH: USB Bluetooth 2.X EDR Dongle with Led Light Thumb Size [+12]
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation [+10]
CARE3: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
CAS: * Azza Genesis 9000 Full Tower Gaming Case w/ 2 x 230mm fans, 4x Easy Swap HDD, Dual Power Supply Support, & front USB 3.0 Port (White Color)
CASUPGRADE: Flexible LED Interior Light Strip [+19] (Blue Color [+0])
CC: None [-187]
CD: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo Drive (BLUE COLOR [+9])
CD2: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo Drive [+61] (BLUE COLOR [+9])
COOLANT: Standard Coolant
CPU: AMD FX-8150 3.60 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology
CS_FAN: Maximum Enermax 120MM Case Cooling Fans for selected case (Maximum Silent Operation) [+29] (500-1,200 RPM T.B. Silence Black Color with Blue LED Twister Bearing 8-14 dBA [+0])
ENGRAVING: None
FA_HDD: Vigor iSURF II Hard Disk Drive Cooling System [+21] (3 x Systems [+42])
FAN: Asetek 570LX Liquid Cooling system w/ 240MM Radiator and Dual Fans (Extreme Overclocking Performance + Extreme Silent at 20dBA)
FLASHMEDIA: All-in-One External USB 2.0 Card Reader/Writer (Black Color) [+11]
FREEBIE_CS: None
FREEBIE_MB: None
FREEBIE_VC: None
FREEBIE_VC2: None
GLASSES: None
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [-16] (Single Drive)
HDD2: 1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD (1TB x 2 (2 TB Capacity) Raid 0 Extreme Performance [+94])
IEEE_CARD: IEEE 1394 CARD AND DRIVER [+19]
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MEMORY: 32GB (8GBx4) DDR3/1333MHz Dual Channel Memory [+18] (Corsair or Major Brand)
MONITOR: 24" Widescreen 1920x1080 Sceptre X246W-1080P LCD (Viewable 23.6")(Black Color) w/ Built-in Speaker, DVI & Input [+219]
MONITOR2: None
MONITOR3: None
MOPAD1: Razer Vespula Dual Sided Gaming Mouse Mat [+31]
MOTHERBOARD: [CrossFireX/SLI] ASUS Sabertooth AMD 990FX R2.0 Socket AM3+ ATX Mainboard w/ UEFI Bios, TUF Thermal Radar & Components, 7.1 HD Audio, GbLAN, 4 Gen2 PCIe X16, 1 PCIe X1 & 1 PCI [+90]
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Sound Absorbing Foam on Side, Top And Bottom panels [+29]
NOISEREDUCE2: Power Supply Gasket [+5]
NOISEREDUCE3: Anti-Vibration Fan Mounts [+9]
OS: Microsoft® Windows 7 Ultimate [+105] (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: * 1,000 Watts - Cooler Master Silent Pro Gold 80 Plus Power Supply ( 80 Plus Gold) [+81]
PRINTER_CABLE1: PPA 6FT HDMI to DVI 18+1 Male Black Cable [+10] (1 piece)
RUSH: 5% Instant Rebate for NO-RUSH Delivery, order will ship in 3 to 4 Weeks. Must Enter Coupon Code "NORUSH" during checkout [+0]
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOFT1: McAfee AntiVirus Plus 2013 [+15]
SOFT2: McAfee Internet Security 2012 [+19]
SOUND: * ASUS Xonar DS 7.1 Channels 24-bit 192KHz PCI Audio Card [+49]
SPEAKERS: 600Watts PMPO Subwoofer Stereo Speakers [+15]
TABLET: None
TEMP: Aerocool Touch 2000 Dual Bay Touch Screen Fan Control [+39]
TVRC: None
USB: External USB 3.0 4-Port Hub [+29]
USBFLASH: USB 3.0 Portable Flash Drive [+20] (16GB [+7])
USBHD: Thermaltake BlacX Duet Dual Hard Drives Docking Station [+49]
USBX: NZXT Internal USB 6-PORT Expansion Module + USB Bluetooth 2.X EDR Dongle with Led Light Thumb Size [+29]
VIDEO: AMD Radeon HD 7970 3GB 16X PCIe 3.0 Video Card [+127] (HIS IceQ Edition [+50])
VIDEO2: AMD Radeon HD 7970 3GB 16X PCIe 3.0 Video Card [+402] (HIS IceQ Edition [+50])
VIDEO3: None
VIDEOCAMERA1: Creative Live! Cam Chat HD 720p w/ Noise-Canceling Microphone [+32]
WNC: None
_PRICE: (+3285)
_view_: {97E20924-6A7C-421B-9EA8-A2BEACDAAF78}
_load_: 1/27/2013 3:16:47 PM
 Post subject: Re: Is this computer from cyberpowerpc worth $3285
PostPosted: Sun Jan 27, 2013 3:45 pm
Do we need to do this again?
viewtopic.php?f=35&t=232821
Spec and build your own machine and save $2200!
PostPosted: Sun Jan 27, 2013 3:50 pm
No computer is worth spending $3285 on. Let alone any more than $1500.
PostPosted: Sun Jan 27, 2013 8:14 pm
You can buy better parts and pay someone to make it for less
PostPosted: Sun Jan 27, 2013 9:16 pm
Million Club - 5 Plus
If he's asked twice, I think that he's waiting for a better answer than you guys are giving him.
PostPosted: Sun Jan 27, 2013 10:01 pm
We all basically answered his question. He can continue to post builds until he asks the right question.
PostPosted: Mon Jan 28, 2013 7:53 am
I have to agree, you can do it much cheaper yourself. Those online places tend to gouge you quite a bit for what they offer.
PostPosted: Mon Jan 28, 2013 1:53 pm
A few things I noticed on the parts list that you should reconsider
The CPU - Get an Intel cpu, if you don't mind spending that kind of money on a computer than you may as well get an Intel cpu like a i7 3770k or something. You've obviously got performance in mind because...
The Video Cards - You selected 2 highest-end video cards, which is fine if you've got the penny to pay for it, but one should be more than fine and save a lot of money
The speakers - 600w PMPO subwoofer speakers? Because it says "pmpo" you can almost certainly be sure that they are probably 10w rms cyber acoustic speakers. Look up what PMPO means, it's a pretty useless number. Whatever you're paying for them it's too much, you can pick up some cheap logitech speakers at walmart and be much better off.
The power supply - With just one video card you won't need 1000w and could do with 700/800w and still have more than you need. (someone verify this for me)
Also, do order the parts individually and build it yourself, it'll come out much much cheaper.
www.pricewatch.com is a good place to look up places selling the parts for the least.
If you're adamant on not wanting to build it yourself a good place I've done business with before is www.portatech.com. They are very reasonable with most of their prices but you may want to get the video card separately to save a little.
