It is currently Mon Apr 20, 2015 9:34 pm
 Post subject: Which graphics card is better ?!
PostPosted: Sat Jan 26, 2013 12:38 pm
I have built my gaming pc except for the gpu :(
which one to get ? :
GTX680 lightning
-OR-
GTX680 gigabyte oc 2gb
and is 2gb of vram enough for future gaming ? or should I go with a 4gb ?
my build :
Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I53570K
Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive Bulk/OEM - WD1002FAEX
Corsair Enthusiast Series 650-Watt 80 Plus Bronze Certified Power Supply Compatible with Core i3, i5, i7 and platforms - TX650
Corsair Vengeance 8GB (2x4GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CML8GX3M2A1600C9)
AS Rock LGA1155 DDR3 SATA3 USB3.0 Quad CrossFireX and Quad SLI A GbE ATX Motherboard Z77 EXTREME4
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
Samsung Electronics 840 Pro Series 2.5-Inch 128 SATA_6_0_gb Solid State Drive MZ-7PD128BW
 Post subject: Re: Which graphics card is better ?!
PostPosted: Sat Jan 26, 2013 4:30 pm
WELCOME! Welcome to the MaxPC FORUMS. Please make sure you don't just play a voyeur - be sure to actively contribute, advise and help someone else out. This place is only as good as it's participants - it's all about quality and timely I/O.
You sure you need a 680? What resolution are you pushing? A 670 hits 92% of a 680 and a 7970 blows past it for >$100 less. Use that savings for wickedly fast 256Gb Vector or 840 Pro.
PostPosted: Sun Jan 27, 2013 7:15 am
Yes, welcome to the forums!
you don't mention the monitor setup you have - that would help determine your GPU needs. If you're rockin' with a 23" single monitor at 1080p, then the 670 would be perfect (NCIX actually has one for $280 after rebate). If you're sporting 2x 27" 1920x1200 monitors, then the 680/7970 makes more sense.
While I prefer nVidia, Kleinkinstein has makes a good point of suggesting the 7970 (though I wouldn't say it "blows past" the 680 - I think it "trades blows" with the 680). One thing AMD is offering are some AAA games for free with some of their GPUs (I think it's still going on), so that could influence which GPU you get.
As to your 2GB/4GB VRAM question, I wouldn't worry about it - focus on your needs now and in the next 6 months. By the time the VRAM becomes an issue, you'll probably be ready to get a new GPU anyways.
Hope this helps.
PostPosted: Sun Jan 27, 2013 12:43 pm
Semantics. I was going for effect! :wink:
