It is currently Mon Jun 17, 2013 10:39 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
 Post subject: computer build
PostPosted: Tue Jan 22, 2013 11:13 am
http://www.newegg.com/Product/Product.a ... 6811322016 case
http://www.newegg.com/Product/Product.a ... 6822136771 HDD
http://www.newegg.com/Product/Product.a ... 6813131873 motherboard
http://www.newegg.com/Product/Product.a ... 6814161426 GPU
http://www.newegg.com/Product/Product.a ... 6817182200 PSU
http://www.newegg.com/Product/Product.a ... 6820233144 ram
http://www.newegg.com/Product/Product.a ... 6819113286 CPU
http://www.newegg.com/Product/Product.a ... 6835186059 aftermarket cooler
i'm little worried about space
mostly going to play planetside 2 and some other smaller games while on youtube and other stuff
also http://www.newegg.com/Product/Product.a ... 6835103099 would be better then the one i picked ?
 Post subject: Re: computer build
PostPosted: Tue Jan 22, 2013 2:18 pm
250GB HDD? You can get 500GB for the same price I believe.
PostPosted: Tue Jan 22, 2013 2:24 pm
Your build looks pretty good, but I would suggest you go with the Cooler Master EVO cooler definitely over the other cooler you selected. I would also recommend that you go with the Corsair Carbide 200R case, as it has a tool-less design for all drive bays and great cable routing. I would also recommend this Corsair 500 Watt power supply over the Rosewill one.
Here are my links
Corsair Carbide 200R http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
Corsair 500 Watt Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
PostPosted: Tue Jan 22, 2013 2:28 pm
Here are my links
you do no in one year i will get close to 600 watts from ageing and that case has no fans o.o
and the HDD i been seeing lot of DOA
PostPosted: Tue Jan 22, 2013 2:35 pm
i could get a http://www.newegg.com/Product/Product.a ... 6817148022 but that's little over board with my power
PostPosted: Tue Jan 22, 2013 2:40 pm
also i made some small changes
http://www.newegg.com/Product/Product.a ... 6820148656 timing is faster and it's cheaper
PostPosted: Tue Jan 22, 2013 3:22 pm
The 200R has one rear fan.
PostPosted: Tue Jan 22, 2013 3:27 pm
People who have bad experiences will more likely review a product than people with good experiences.
Also actual DOAs means nothing. RMA it, get a replacement. Now if it were a month and it poops out, I'd be angry.
PostPosted: Tue Jan 22, 2013 3:53 pm
you hear yourself right there high mid ranged PC one fan ?
PostPosted: Tue Jan 22, 2013 5:17 pm
anyone else out there ? o.o
and windows 7 or 8 ? i don't care how hard it is to learn
PostPosted: Tue Jan 22, 2013 6:17 pm
pcpartpicker say's it's 332W
eXtreme Power Supply Calculator say's 461W
what one should i believe more o.o
PostPosted: Tue Jan 22, 2013 6:21 pm
Do you love the start menu to the point where if it went away, you'd hate Microsoft forever? Windows 7.
Do you want to be up to date and all that jazz? Windows 8.
Do you not give a damn? Windows 7
PCPartPicker may be showing you the minimum you need. eXtreme's big fat number is the recommended, find the smaller one that's minimum. I take eXtreme's with more weight.
Also remember that eXtreme's defaults the utilization of your system to 90%. Even if you're running Crysis 2 on Ultra settings, your computer isn't going to touch 90% utilization. This is more like running FurMark and Prime95 at the same time.
Also don't use "kao moji". It looks silly.
PostPosted: Tue Jan 22, 2013 6:26 pm
so a 600 watt would be best ?
PostPosted: Tue Jan 22, 2013 9:15 pm
Yes.
PostPosted: Tue Jan 22, 2013 9:20 pm
I'm starting to think a 120 SSD hard drive will be good for me I'm only using 50 GB on here
But up to you guys lol
PostPosted: Tue Jan 22, 2013 11:12 pm
Well I can drop the CPu fan and lower the gpu to a 7770 but I hear bad stuff about SSDs being the main hard drive and it will be a 264 gb one if I do that
But up to you
PostPosted: Wed Jan 23, 2013 10:04 am
morning
PostPosted: Wed Jan 23, 2013 10:14 am
Get a 256Gb, it's the sweet spot for now. You won't regret it. And Truth be told, we will have economical 500GB and 1TB ssd's by the end of the year. Get the 840 Pro, Vector or 830. Test drive 'em here.
PostPosted: Wed Jan 23, 2013 10:32 am
is it even worth it to down grade my computer just for a SSD ?
PostPosted: Wed Jan 23, 2013 10:39 am
Yes, absopositively! An ssd is the single biggest upgrade you can EVER make right now. But why would you downgrade? What is your budget and current spec? We can fit it all in! ......that's what she said.
