It is currently Tue Jan 27, 2015 10:37 pm
 Post subject: graphic card for awsome gaming pc
PostPosted: Sat Jan 19, 2013 9:06 pm
so i need help BUILDING THE GREATEST GAMING PC. my friend has recently talked me into building my own pc ive nevr down this and its always seemed very intimadating. dont really know much bout how the componets work inside i just use them lol. soooooooo my question for now is would it be better to run 2 gtx 660 ti 2gb. or 1 gtx 690 4gb? which would run better and which would be able to run ever things on ultra high settings with 0 and i mean 0 lag issues?
 Post subject: Re: graphic card for awsome gaming pc
PostPosted: Tue Jan 22, 2013 2:59 pm
A 690 will run better than two 660Ti video cards in SLI since a 690 is two 680's crammed into one video card. Both setups will run well in terms of gaming, but if your gaming at a resolution of 2560x1440 you will want to go with the 690 as it will perform better at higher resolutions. If you're just gaming at 1920x1080 both will be fine your needs.
PostPosted: Tue Jan 22, 2013 3:06 pm
If you can afford a GTX 690, you can afford two GTX 670s, which will perform as good or better than a GTX 690 for less.
And to reiterate the point: if you're gaming at 1920x1200 or lower, you will be pissing money away on anything that packs more punch than a GTX 670/Radeon HD 7970.
PostPosted: Thu Jan 24, 2013 8:27 pm
Soo 2 gtx670 well be plenty for arma 2 at highest settings and will look great with no lag what so ever. Btw im getting the i7 3770k. I want it so that when shit hits the fan and everthing starts exploding in the game that I wont miss any of it and be lagging...... I mean I dont even wanna lag for just a sec. I want it to chuck norries the graphics and not miss a beat... lol sry just wanna get the point across. O and my spending I set for my self is $2300-2500
PostPosted: Mon Jan 28, 2013 10:21 am
Arma II isn't a very demanding game you could run it with a lone 650Ti at max settings easily. If you want a dual card SLI setup 2 670's would be the best option in terms of value/performance.
