It is currently Mon Jun 17, 2013 10:21 pm
 Post subject: New MoBo
PostPosted: Mon Jan 14, 2013 12:53 pm
I purchased a GT 440 and a Intel Core 2 Duo E6750 for my friends PC because he bought a ton of PC games and they wont run and well he doesn't want them. Why? No clue. But I am now like OK... now I have these extra PC parts... now what? So I figured I would build a PC with them. I have a GT 440, Core 2 Duo E6750, 2GB DDR2, 250GB SATA HDD, Rosewill Case with 300W PSU and Windows 7 64 Bit OS. But still need a MotherBoard. I need a motherboard that will support a E6750 CPU. Was looking at this one http://www.ebay.com/itm/Intel-GM819-Del ... 0856127986 Will it work?I want it as cheap as possible. I have seen some that support the E6700 but the E6750 seems to be more picky.
Need motherboard that's Cheap and supports the Core 2 Duo E6750.
Thanks!
 Post subject: Re: New MoBo
PostPosted: Mon Jan 14, 2013 2:39 pm
That's a Dell board. Always assume Dell/HP/etc. boards are incompatible with stuff you can find on Newegg because 1. They're BTX (nobody supports it) and 2. They may muck with the power supply cable, leading to non-standard connections that will fry either the PSU or the board if you don't buy a matching part.
Speaking of which: http://www.newegg.com/Product/Product.a ... 6813157337
PostPosted: Mon Jan 14, 2013 3:50 pm
Would this Motherboard be a good choice? http://www.ebay.com/itm/Biostar-G31-M7- ... 3f20f61a68
PostPosted: Mon Jan 14, 2013 3:57 pm
Honestly I would just buy something new. You'll more than likely buy the eBay stuff "as is" and a price difference of $40 shouldn't be that bad.
PostPosted: Mon Jan 14, 2013 6:41 pm
Sounds very nice.
PostPosted: Tue Jan 15, 2013 12:19 pm
here are some still new boards, myself I would rather buy new than ebay.http://www.geeks.com/products_sc.asp?cat=472
