I currently have chosen what I want to use in my build, but the motherboard seems to be the most confusing part for me to understand. So, due to me not having much knowledge, I have turned to this forum to see if someone can help me find a motherboard that suits my needs. So, currently, I have chosen the following items to be in my build:
Intel pentium g850
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116397Xfx double d hd 7700
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150597Corsair 8Gb RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186As well as these things, I would also like space to add an internal wifi card if needed, because I will be moving this summer, and do not know if I will have easy access to an ethernet cable.
I also need these things, a VGA and an HDMI port and at least 4 USB ports.
I have not yet decided on a case, but I would like the motherboard to be either ATX or Micro ATX.
I will be using this computer for mostly gaming and a few other things, but i do not need to have the best quality motherboard out there, but would like one that wouldn't die out on me, or damage anything connected to it, so it needs to be reliable.
I would like to stay under $150 and under $100 would be ideal.
If anyone can help me out that would be greatly appreciated, and please ask any and all questions you may need the answer to.
