It is currently Sat Apr 25, 2015 7:29 pm
 Post subject: how do you overclock??
PostPosted: Wed Aug 11, 2004 10:53 am
ok im about to build a new system and im probably going to get a amd athlon xp 2600.
http://www.newegg.com/app/ViewProductDe ... 418&depa=0
i want to overclock it but i dont know how. also right now im running a p3 850mhz and it really stinks so i want to overclock this processor.
could someone please help. thanks!
shane
PostPosted: Wed Aug 11, 2004 11:00 am
try checking these links http://www.tweakfactor.com/articles/tweaks/neoocguide/1.html
http://www.helpoverclocking.com/english/ (Possibly outdated)
PostPosted: Wed Aug 11, 2004 12:09 pm
INFINITE vCORE
INFINITE vCORE
There is always the venerable www.overclockers.com as well...
PostPosted: Wed Aug 11, 2004 2:42 pm
if you are looking to overclock, get a athlonxp-m. they run at lower voltages, which means cooler temps, and more headroom. it isnt uncommon to have a xp2500-m running over 2400-2500 mhz, (about a 600-700mhz overclock) on good air cooling. newegg has the 2500's for about 95$ right now
http://www.newegg.com/app/viewProductDe ... 401&depa=0
PostPosted: Wed Aug 11, 2004 5:14 pm
im new to overclocking and was debating rather to get an amd xp or 64, for a newb would the xp be the better choice and would i see the real difference bethween the two.
PostPosted: Wed Aug 11, 2004 9:02 pm
depends on what you will use it for, how much you are looking at spending, things like that - a good place for info is http://www.anandtech.com - they have all kinds of reviews/benchmarks for just about everything
PostPosted: Thu Aug 12, 2004 2:08 am
I'd actually say to get an old celeron system to play with at first. That's what I did at least. The older P3 era celies were great toys to tinker with. May be hard to find today, but I'm sure ebay has a few:p
PostPosted: Fri Aug 20, 2004 8:40 pm
Shuttel AN35N Ultra. XP2500 Barton on an 11X multiplier (because they are locked now), or a mobile XP2500. Done. This way you can just use your existing PATA IDE hard drivers. The shuttle overclocks very well.
Users browsing this forum: FascistNation and 9 guests
