It is currently Tue May 21, 2013 11:43 pm
 Post subject: Motherboard Processor change help needed
PostPosted: Sat Dec 08, 2012 11:31 am
I currently have an Asus P8P67 Deluxe MB fitted with a sandy bridge 2600k processor.
Ram is 16G of DDR3 @ 1.6GHz Windows 7 Professional
I would like to upgrade to a newer MB with a faster processor.
My question / concern is:
Since I currently have hundreds of programs, games, files, etc on my current system, is it possible to upgrade the MB/proc and NOT have to reinstall everything again? I'm not even sure I can find all the program discs for everything any more.
I'm basically looking for the least painful way of doing this and any help would be appreciated.
 Post subject: Re: Motherboard Processor change help needed
PostPosted: Sat Dec 08, 2012 12:36 pm
If you can separate the programs from the OS, you can reinstall the OS just fine if need be. Most programs don't need to go through an install process to work, except if they need to be activated.
PostPosted: Sat Dec 08, 2012 12:55 pm
I'm not sure I understand how to do that separating programs from OS
Can you explain how that would be done?
PostPosted: Sat Dec 08, 2012 2:09 pm
I do know that for the most part, the hard drives themselves should have little to no changes being made. You're likely to keep all of your personal data, but the programs are questionable as to how they have to be treated when it comes to reinstalling and activating. Windows 7 should easily contact the Update section itself to install their drivers for the new motherboard, processor, graphics card, ect., to support your changes. Try doing that with XP, though...
PostPosted: Sun Dec 09, 2012 1:28 am
Just copy and paste the folders to another partition/hard drive.
PostPosted: Sun Dec 09, 2012 9:25 am
And depending upon the software, you'll need to map over the new destinations within the Registry.
PostPosted: Sun Dec 09, 2012 9:56 am
I was afraid of that. Is there any way to automate that process?
I'm not too keen on messing with the registry. Seems like I would
be better off just reinstalling.
PostPosted: Sun Dec 09, 2012 10:41 am
No, I've even dabbled in the registry to look for a few things, and I'm even convinced there's no real guarantee it'll work.
But most programs are really "portable", in that once you install them, that's it, you can run them wherever. It's only the programs that require activation that I have a problem with.
PostPosted: Sun Dec 09, 2012 2:06 pm
Anything in the Sandy Bridge/ Ivy Bridge line you shouldn't need to reinstall much if anything. Only way to really find out is to try it.
Why do you need something faster than a 2600k? It still holds it own against the latest and greatest while being a great overclocker. At least overclock it to 4.5 and see if it meets your needs.
PostPosted: Sun Dec 09, 2012 2:50 pm
Well, the main reason is, I do a lot of audio recording and my audio interface is firewire. I am starting to experience some issues with my onboard firewire port. Switching to USB is not an option since my audio interface/digital mixer runs about $1300 retail. I built my current system almost two years ago (march will be 2 years) and to buy more upgrade-ability, I felt I needed to go for a 2011 mb form factor. Personally, if I can get one or two more years out of this one that would be great but I also don't want to fall behind the tech curve too much. Btw, I also do a bit of 3d animation, video editing and play games, so the more powerful the system for me the better.
PostPosted: Sun Dec 09, 2012 4:19 pm
Firewire? Really and for real? Why? I've finally found the one user. OMG!
PostPosted: Sun Dec 09, 2012 6:01 pm
Hehe, actually in the world of audio recording firewire is not uncommon. I'm sure with thunderbird, it will phase out, but it is currently still very common. Probably not so much so with the enthusiast as is populated by this board.
without wanting to cause a debate on the subject, check this out http://www.qimaging.com/support/pdfs/firewire_usb_technote.pdf
it's pretty informative. Plus FW400 can handle 100 simultaneous channels, whereas USB 2.0 can only handle 16. Personally I would rather not have to deal with firewire, but the higher quality audio stuff seems to have it included.
