It is currently Sat Feb 28, 2015 4:52 pm
 Post subject: I need help buying some RAM
PostPosted: Wed Dec 05, 2012 7:52 pm
Hi guys, I need more RAM do to editing software (plug-ins). What type of RAM should I get?
Operation System:
Windows 7 64-bit Service Pack 1
CHIPSET:
Rampage Formula
X48
Processor:
Intel Core 2 Quad Q9650
Socket 775 LGA
Current Ram:
DDR2 Kingston 1066 Native(PC3-6400 "800Mhz") 4GB
 Post subject: Re: I need help buying some RAM
PostPosted: Wed Dec 05, 2012 8:07 pm
you can do what I did, go on ebay and check for ram that is the same as what you have in there already. my problem was that I had OCZ memory which had quit making ram so I had to buy used, problem was it was high end memory, and it took a month to find a pair of sticks that matched my timing. should be cheaper than buying new or having to buy 8gig of matched. I am assuming that you have 2 sticks of 2gig now. it should be pc2 6400 though.
http://www.ebay.com/sch/Memory-RAM-/170083/i.html?_from=R40&_nkw=DDR2+Kingston+800Mhz&_dmpt=US_Memory_RAM_&Form%2520Factor=DIMM&rt=nc
or see if you can match it here with new memory http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007611%2050001183%20600006042&IsNodeId=1&name=Kingston%20Technology%20Corp.
PostPosted: Thu Dec 06, 2012 11:59 am
Seems like it might be cheaper to just get this:
http://www.frys.com/product/7297993?sit ... IN_RSLT_PG
Not sure if it w
ould work with my chip set though. I went to Intel x48 specs and it seems that it would work. Any suggestions?
PostPosted: Thu Dec 06, 2012 1:01 pm
No, your motherboard only supports DDR2.
PostPosted: Thu Dec 06, 2012 7:12 pm
and most 775 boards only support 8gig max, and do not support 4gig sticks.
http://www.amazon.com/PC-Memory-Computer-Add-Ons-Computers/b/ref=amb_link_7062002_3?ie=UTF8&node=172503&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-1&pf_rd_r=14QD2KEWT11E0FJFNQ0V&pf_rd_t=101&pf_rd_p=1409885162&pf_rd_i=193870011#/ref=sr_nr_p_4_1?rh=n%3A172282%2Cp_4%3AKingston&bbn=172503&ie=UTF8&qid=1354869999&rnid=15784691amazon has a bit also.
PostPosted: Fri Dec 07, 2012 3:40 pm
Thanks for the help guys. I think I am just going to take waters suggestion and get the same thing that's in there.
