It is currently Wed Jan 28, 2015 2:12 am
 Post subject: AMD VS Nvidia / CS6 AutoCAD
PostPosted: Sat Dec 01, 2012 7:46 am
Which one is better at running Adobe CS6, AutoCAD and other HD video editing programs or are they both about the same?
Thanks
 Post subject: Re: AMD VS Nvidia / CS6 AutoCAD
PostPosted: Thu Dec 13, 2012 5:50 pm
Here are their new specs to run their program:
http://blogs.adobe.com/jnack/files/2012 ... ations.pdf
PostPosted: Fri Dec 14, 2012 7:43 am
I thought CS6 supported both Nvidia and AMD? :? ?
PostPosted: Fri Dec 14, 2012 7:50 am
It will probably work but not render as fast.
PostPosted: Sat Dec 15, 2012 8:48 am
Nastyman
Thanks for the Info!!
I found this on the Studio 1 Productions website.
(http://www.studio1productions.com/Artic ... toShop.htm)
It looks like Adobe is slowly moving away from CUDA (Nvidia) and going to OpenGL and OpenCL. But if you want to use CS5, 5.5, Premiere or After Effects you’re going to need an Nvidia card.
