It is currently Thu Mar 05, 2015 10:55 am
 Post subject: Pump for water cooling question
PostPosted: Mon Aug 02, 2004 1:08 pm
Hey
What would be a good GPH amount for a pump??? stupid short question hoping for a smart answer.. the tank is big like BIG its an old ari compressor tank with tubing for the water to follow sotof a makeshift water radiator. Then again a car radiator wouldent be that bad of an idea.
Quick to the junkyard..... :lol:
PostPosted: Mon Aug 02, 2004 8:38 pm
Actually, right now theInnovatek HPPS 12v Pump(eheim mod) is really hard to beat if you have the space...and it is 12V DC, so it's quiet! A Hydor L30 is another great pump that's floating around out there. I generally didn't like the Eheim's until they got this 12V unit. They were just overpriced IMO.
If space is a concern, the little Danger Den DD12V-D4 pump is a great pump as well.
I'd look at the "rise hight" or "bars" as a good figure to compare pumps as well. If you decide to add more than CPU cooling, then pressure supply will become a large issue along with your choice of tubing diameter. And also take into account that the mixture of glycole and the likes will lower the rated performance. But basically, 160-200 GPH* is a good figure.
*Rated. As per the article below, real life rating is closer to 50.
http://www.overclockers.com/articles723/
