It is currently Sat Apr 18, 2015 7:49 am
 Post subject: Can I revive this?
PostPosted: Fri Nov 30, 2012 3:33 am
Hello friends,
I am new to this forum and I need your thoughts and expertise:
I want to build an HTPC and before I go out and buy anything, I would like to see if I can do anything with an AOpen XCube EZ 65 that sits in a closet
Details for the XCube can be found in the following http://global.aopen.com/products_detail.aspx?auno=7:
This thing is a SFF barebone that came out some years ago.
The idea is to remove everything from inside and put a new motherboard, cpu disks etc...
What I am trying to find out is if ASROCK FM2A75M-ITX motherboard or something similar would fit in there. I am aiming to use the AMD A6-Series A6-5400K
So the question is if it is possible to put that mobo in there.
If this happens, then for sure everything else can fit too..
Any ideas?
Thank you for your time
