It is currently Fri Mar 27, 2015 11:28 am
 Post subject: Buildin a new computer!
PostPosted: Sun May 01, 2005 11:17 am
Well, I was righting this thread 5 minutes ago, but that was before my computer crashed. So I had to make a new one :(
I am pretty much an extreme gamer and I do some video editing.
price range is 1500 +- 200 (canadian) so about 1200 American.
I live in Canada so I will most likely be using zipzoomfly since they ship to Canada.
I will recycle my audigy 2 zs and my periphials (mouse keyboard monitor etc)
I am hoping to get dual gfx card, but I can live with one right now and then upgrade to two later. Also I wanna use AMD and geforce most lickely (PCI)
Thank you for your help!
PostPosted: Sun May 01, 2005 3:48 pm
Personal preference but....
MB
MSI Neo......SLI
http://www.zipzoomfly.com/jsp/ProductDe ... ode=241167
160
Processor
amd64 3500+
http://www.zipzoomfly.com/jsp/ProductDe ... de=80717-R
270
RAM
Corsair ram
http://www.zipzoomfly.com/jsp/ProductDe ... e=80097-04
105
CD
Liteon 52x32x52 cdr/rw etc.
http://www.zipzoomfly.com/jsp/ProductDe ... ode=170656
30
HD
maxtor diamond 120 sata
http://www.zipzoomfly.com/jsp/ProductDe ... ode=100705
86
PSU
Not sure if it is SLI but...
antec 550 truepower
http://www.zipzoomfly.com/jsp/ProductDe ... ode=270009
104
Case
Antec superlanboy
http://www.zipzoomfly.com/jsp/ProductDe ... ode=140109
80
Video Card
personally I would go with this 6800GT and add one later but...
http://www.zipzoomfly.com/jsp/ProductDe ... ode=322716
360
if you must have two cards then get 2 6600 gt's. I think from the benches they arent as strong as one 6800gt could be wrong though.
Since all that is free 2day air, you should come out to about 1195. I am assuming you have case fans and stuff though. If you need to cut back on something I would cut back on the 3500 and go with 3200 cause like i said in another forum, my friends goes to 2.5 and he is sitting at 2.2 on stock air.
PostPosted: Sun May 01, 2005 8:55 pm
After looking around for a bit, I was looking at the alienware http://www.alienware.com/product_detail ... EFAULT#sub
ALX I thought I might as well do the monthly payment plan and get the best PC out there.
But is it really worth the 5 grand?
PostPosted: Mon May 02, 2005 6:36 am
probably not , but if it makes you happy. You cant puta price on happiness. /ends credit card commercial.
In all seriousness the only reason it could possibly be worth it, is cause it allows you to pay for a computer over time. I could not justify paying 4g's for a computer though. Your call though, GL.
 Post subject: Nope
PostPosted: Mon May 02, 2005 6:39 am
It won't be by the time your done paying for it. I think you'd be better off spending 2G's on a nice computer now than make payments on something you're gonna want to replace by the time you pay it off. Just my .02 cents.
