It is currently Wed May 22, 2013 3:07 am
 Post subject: copper or... not copper
PostPosted: Thu Apr 28, 2005 5:15 pm
I am about to get a new heat sink. should I get the thermalrigh xp-90 or 90c copper. <that one is heavier but because it is copper won't it cool better too? a little advice along with a fan recommendation.
PostPosted: Thu Apr 28, 2005 5:18 pm
Smithfield*
Smithfield*
the copper version has only SLIGHTLY better cooling ability. but i wouldnt say its worth haveing a 2 pound copper weight hanging off your mobo. Go with the regular version and a panasonic panaflow fan.
PostPosted: Thu Apr 28, 2005 5:36 pm
Newegg show a $22 difference between the two. I would go with the lower cost one unless you are cooling a Prescott CPU, or an overclocked CPU.
PostPosted: Thu Apr 28, 2005 7:33 pm
Celeron
Celeron
The XP-90 is spectacular in terms of price to performance compared to it's new born orange brother. According to reviews, it looks like there's a small, negligeable difference in cooling between the two.
PostPosted: Thu Apr 28, 2005 10:04 pm
on SVC the xp90 aluminum is 30 bucks the copper verson is 50 dolars but if u want to get it, that would probably be the cheapest
