It is currently Fri May 24, 2013 7:37 am
 Post subject: New video editing machine
PostPosted: Wed Nov 07, 2012 7:30 pm
Looking at building a new video editing machine. Don't game at the moment but maybe in the future.
Need a monitor, OS, etc.
Looking to keep it under $1000
Here is what i have so far and what i need help on.
CPU: Intel Core i5-3570K
MOBO: ASRock Z77 Extreme4
PSU: CORSAIR Enthusiast Series TX650
RAM:CORSAIR Vengeance 8GB
HDD: Seagate Barracuda ST31000524AS 1TB 7200 RPM
Monitor: Acer S231HLbid Black 23" 5ms HDMI LED (Is this ok??)
Optical: ASUS 24X DVD Burner
Case: Corsair Carbide Series 300R
GPU: ???
OS: Windows 7 64bit
So with all of this it looks to be around $871.90
Do i need a dedicated GPU if i'm going to be editing in 720p and 1080p??
 Post subject: Re: New video editing machine
PostPosted: Thu Nov 08, 2012 5:23 am
Very good work. Few suggestions, but first off...nope. You don't need a dedicated GPU. And if you don't game and if/when you do it sounds as if it might just be casual, I'd just start off the Ivy integrated HD4000.
If time is critical in your video work, then step up to HT and get the 3770k instead. You can find what HT does in video crunching here
Nice and solid board with great reviews. If you're not going to OC hard then look into the Asrock Pro4. Both it and the 3770k can be had for $330 at MicroCenter in their bundle deal. I've really been impressed with the past half dozen or so Asrock boards. At the price:performance I'd easily take them over Asus any day.
Good psu, but the Seasonic X series is better. Even so, you don't need 650w if no GPU. Aim for a 500w unit, like [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817171038&nm_mc=EMC-IGNEFL110812CO&cm_mmc=EMC-IGNEFL110812CO-_-EMC-110812-Index-_-PowerSupplies-_-17171038-L08Bthis $35[/url] Coolermaster.
Meh! You can do much, MUCH better with these low voltage Samsungs or if you want to go 2x8 then this ultra high performing Mushkin
A 1.5TB Barracuda is $70, the 2TB is $90, and the 3TB is $120...it's king!
This 26" Hanns-G is a great buy at $170 shipped if you want to stay at 1080p. Personally I'd crank it up to 1200 or even 1440 for video editing.
Better is this Samsung
If you say so. I was woefully unimpressed with it in person
GPU: ???
OS: Windows 7 64bit
Go Pro so you'll have access to >16GB of memory
Lastly, you simply must pick up an ssd for the OS and file swapping. Look no further than the Samsung 830/840 or the Crucial M4 in either the 128 or 256 flavor...$70 and $160 respectably.
PostPosted: Fri Nov 09, 2012 2:36 pm
thanks for the help! Looks like i just missed the Hanns 26" monitor...it's not at $160 anymore :(
