It is currently Sun Feb 01, 2015 12:41 pm
 Post subject: Laptop Cooler
PostPosted: Sun Nov 04, 2012 7:49 pm
I need a laptop cooler. I want one with one or two replaceable 120mm fans or a replaceable 140mm fan. Also smaller is better.
 Post subject: Re: Laptop Cooler
PostPosted: Sun Nov 04, 2012 9:06 pm
Replaceable as in what? Using regular case fans? That's not going to happen.
PostPosted: Sun Nov 04, 2012 9:15 pm
Crap I was hoping to put a really quiet 120mm fan in one. What are my options for a silent laptop cooler for a 15" laptop? What about if I want to go quiet but cooler?
PostPosted: Sun Nov 04, 2012 10:15 pm
Most laptop coolers run quiet anyway since they're run off USB, which is 5V. In comparison, case fans use 12V. How much air they can push (and thus their noise) is a function of their voltage.
If you're expecting cool however, it depends on the laptop. But the most you can really expect is single digits.
PostPosted: Mon Nov 05, 2012 12:57 am
Gonna go with this:
http://www.amazon.com/Gaming-Laptop-Cooling-Turbine-SGA-4000-KKNF1/dp/B004G603E2
Reviews say the fans are replaceable but it needs an ac adapter.
PostPosted: Mon Nov 05, 2012 5:53 am
Wow! 2x140mm spinners! That's either overkill or killjoy, not exactly sure which.
