It is currently Sun May 19, 2013 10:45 am
 Post subject: Build using Dec, 2012 Performance Build $2,000 Budget
PostPosted: Wed Oct 31, 2012 6:57 am
Looking at a new Build...using the Dec 2012 Performance Build as a guide for a $2,000 Budget.
I replaced the GTX 670 with a GTX 660 because I already have a 670 I am going to use in a current machine and I will use the 670 in the new computer and put the 660 in the old one.
Thanks for any comments or suggestions.
NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
GIGABYTE GV-N660OC-2GD GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC ...
SAMSUNG 840 Series MZ-7TD250BW 2.5" 250GB SATA III TLC Internal Solid State Drive (SSD)
CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M2A1600C10
Seagate SV35 Series ST3000VX000 3TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
CORSAIR Hydro Series H100 (CWCH100) Extreme Performance Liquid CPU Cooler
Windows 8 OS
Thanks Again!
Randy
 Post subject: Re: Build using Dec, 2012 Performance Build $2,000 Budget
PostPosted: Wed Oct 31, 2012 7:19 am
Couple of problems
  • No CPU listed.
  • Not enough RAM to populate the minimum required for the board (you need 4 sticks)
A few questions
  • What's the purpose of this build?
  • Are you going to overclock?
    • If not, don't get the Hydrocooler. Get a Cooler Master 212.
PostPosted: Wed Oct 31, 2012 11:59 am
None of these pieces are really optimized for the adjacent parts. Why dump $2 large on an X79 system, when you can land a $1200 3770k rig that with push and pass 2011 in almost everything. What do you need this new machine to do?
PostPosted: Wed Oct 31, 2012 12:23 pm
Ooops...sorry about the CPU.
Got it in there now.
I will be using this computer mainly for Flight Simulator (FSX) Wide Screen....and iRacing. That is mainly what I do. Some First Person Shooter games.
Thanks for the Memory info...I changed that.
Yes I am going to overclock.
Where do I find a decent parts list for this $1200 3770 machine......you definitely have my interest???
And what do you mean the parts are not optimized for the adjacent parts? How do you optimize parts for adjacent parts?
Randy
PostPosted: Wed Oct 31, 2012 12:31 pm
Okay, that's better. Now I can critique
  • The X79 platform is overkill for a gaming computer, which is what I see this as. Get a ~$150 Z77 board and a Core i5-3570K.
  • You won't need 16GB of RAM. 8GB is fine.
  • I'd still opt for a Cooler Master Hyper 212, but go look around. I'm not a fan only because reviews seem to show they don't offer that much more cooling for the cost.
If I were to make an ass pull list on the $1200 price range:
  • Core i5-3570K - $200
  • Z77 board - $150
  • 8GB of RAM - $50
  • GeForce GTX 660 Ti - $330
  • HDD - $80
  • SSD - $100
  • Case - $150
  • PSU - $100
  • OS - $100
That's about $1260 for parts. But go shop around, it's not that hard.
PostPosted: Wed Oct 31, 2012 1:30 pm
Thanks a bunch....I appreciate the help.
PostPosted: Wed Oct 31, 2012 2:00 pm
LatiosXT got you right square in the ballpark. If I had to pull the trigger today, I'd squeeze off...
$170 =3570k
$130 = UD5H with $50 bundle discount
$35 = 8GB Ares 1600
$300 = MSI GTX 660Ti
$120 = 3TB HDD
$130 = 256GB SSD
$70 = Fractal Arc Midi
$100 = Seasonic X750
$40 = meh...Win8ate :roll:
$1095
A guaranteed 90th percentile rig!
PostPosted: Thu Nov 01, 2012 5:02 am
Great Stuff...Guys.
With links to the parts also "kleinkinstein"....fantastic.
Thanks again for your time and ideas.
PostPosted: Thu Nov 01, 2012 9:50 am
Since you're so appreciative, I'm compelled to share that you could...
1. Shave another $70 off with the AsRock Pro4 if you can live with only 8 sata's, 2 usb 3.0's and 1 PCIE 3.0.
2. You don't need 750w, pick up the X650 for $90 instead
3. The MSI is a supersonic GPU, yet the Gigabyte OC is quieter and will put $10 back into your pocket
At $1005, it's a tough rig to beat!
