My current build is subject to change and i only have the case, battery, and hard drives:
i also have a mouse, keyboard, and monitor
also what else do i need to add
CAS:Cooler Master Elite 431 Mid-Tower Gaming Case w/ Side-Panel Window
COOLANT:Standard Coolant
CPU:Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 over clock certified
CS_FAN:Maximum 120MM Color Case Cooling Fans for extras on the case (im overclocking and dont want to take any chances)
FAN:Thermaltake Water 2.0 Performer Liquid Cooling System 120MM Radiator
HDD:1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (FREE Upgrade To 2TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive Only))
HDD2:60GB Corsair Force GT Series SATA-III 6.0 Gb/s SSD - 555MB/s Read & 515MB/s Write [+135] (Single Drive)
MEMORY:16GB (4GBx4) DDR3/1600MHz Dual Channel Memory [+66] (G.SKILL Ripjaws X [+12])
MOTHERBOARD:[3-Way CrossFireX/SLI] ASUS P8Z77-V Deluxe Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, Wi-Fi GO!, 7.1 HD Audio, Dual GbLAN, Display Port, 3x PCIe x16 (2 Gen3, 1 Gen2) & 4x PCIe x1 Over clock certified
{i just copied and pasted the mother board stuff}
POWERSUPPLY:600 Watts - Corsair CMPSU-600CXV2 Builder Series CX600 V2 80 Plus Certified Power Supply
SOUND:Creative Labs SB Audigy SE PCI Sound Card
VIDEO: NVIDIA GeForce GTX 650 2GB 16X {THIS IS NOT OVER CLOCK CERTIFIED SO I DONT KNOW HOW MUCH BETTER IT WILL BE}
WNC:Linksys WMP600N Wireless-N Dual-Band Adapter
So could a few smart computer people help me i dont know much more than basic computer building skills (i helped my friend put in a new video card, change the fans, and put in more ram) so would the video card work fine with over clocking {im not planing on OC more than 10%} its ratings says nothing about OC
also heres a link to a website i built a similar version (it also cost over $500 more than what i can build it for getting the parts separately )
GO HERE
http://www.cyberpowerpc.com/saved/1EJQ5AIF THAT DOESNT WORK TRY THIS
http://www.cyberpowerpc.com/system/Mega_Special_III/THERES A LOAD CODE BUTTON CODE- 1EJQ5A
Thanks for the help if you take the time
