It is currently Thu Jun 20, 2013 4:02 am
 Post subject: Help me build a custom pc i dont know much.
PostPosted: Wed Oct 24, 2012 1:36 pm
My current build is subject to change and i only have the case, battery, and hard drives:
i also have a mouse, keyboard, and monitor
also what else do i need to add
CAS:Cooler Master Elite 431 Mid-Tower Gaming Case w/ Side-Panel Window
COOLANT:Standard Coolant
CPU:Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 over clock certified
CS_FAN:Maximum 120MM Color Case Cooling Fans for extras on the case (im overclocking and dont want to take any chances)
FAN:Thermaltake Water 2.0 Performer Liquid Cooling System 120MM Radiator
HDD:1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (FREE Upgrade To 2TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive Only))
HDD2:60GB Corsair Force GT Series SATA-III 6.0 Gb/s SSD - 555MB/s Read & 515MB/s Write [+135] (Single Drive)
MEMORY:16GB (4GBx4) DDR3/1600MHz Dual Channel Memory [+66] (G.SKILL Ripjaws X [+12])
MOTHERBOARD:[3-Way CrossFireX/SLI] ASUS P8Z77-V Deluxe Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, Wi-Fi GO!, 7.1 HD Audio, Dual GbLAN, Display Port, 3x PCIe x16 (2 Gen3, 1 Gen2) & 4x PCIe x1 Over clock certified
{i just copied and pasted the mother board stuff}
POWERSUPPLY:600 Watts - Corsair CMPSU-600CXV2 Builder Series CX600 V2 80 Plus Certified Power Supply
SOUND:Creative Labs SB Audigy SE PCI Sound Card
VIDEO: NVIDIA GeForce GTX 650 2GB 16X {THIS IS NOT OVER CLOCK CERTIFIED SO I DONT KNOW HOW MUCH BETTER IT WILL BE}
WNC:Linksys WMP600N Wireless-N Dual-Band Adapter
So could a few smart computer people help me i dont know much more than basic computer building skills (i helped my friend put in a new video card, change the fans, and put in more ram) so would the video card work fine with over clocking {im not planing on OC more than 10%} its ratings says nothing about OC
also heres a link to a website i built a similar version (it also cost over $500 more than what i can build it for getting the parts separately )
GO HERE
http://www.cyberpowerpc.com/saved/1EJQ5A
IF THAT DOESNT WORK TRY THIS
http://www.cyberpowerpc.com/system/Mega_Special_III/
THERES A LOAD CODE BUTTON CODE- 1EJQ5A
Thanks for the help if you take the time :D
 Post subject: Re: Help me build a custom pc i dont know much.
PostPosted: Wed Oct 24, 2012 8:07 pm
Welcome to the forums.
Few things:
Are you planning on building yourself, or buying from cyberpower?
What is your budget?
What do you plan to do with the computer? Games, web surfing, etc.
In general, you need the following components to make computer:
*Case
*Motherboard
*CPU
*RAM
*Hard Drive (SSD is optional)
*Operating System (OS)
*Power Supply (PSU)
*Graphics Card (some motherboards include graphics capability - called integrated graphics - so it's "optional" depending on the motherboard) Most computer builds at MPC would include a separate (discrete GPU)
*DVD/BR Drive (also becoming "optional" via obsolescence but I would tend to include one for the time being)
*Keyboard, mouse, monitor, etc.
Give us a little more information and I'm sure someone can help.
