It is currently Fri May 24, 2013 2:22 pm
 Post subject: Worth Updating? Please help
PostPosted: Wed Oct 17, 2012 2:30 pm
I have a 2.5Ghz Dual Core AMD 64 Opteron with 2G RAM and running XP Pro SP3 w/Nvidia GeForce 7900GTX that I use for some old games. Now my son wants to get a new computer and play newer games, unfortunately, the PC he wants is way too expensive. Would it be worth updating this old workhorse, or should I just put it out to pasture? This would be my first do it yourself project. Any ideas would be appreciated.
 Post subject: Re: Worth Updating? Please help
PostPosted: Fri Oct 19, 2012 12:49 pm
You could update your current rig, but building a new one would probably be the best thing to do. I would suggest upgrading your RAM to 4GB and then upgrading your video card to a Nvidia 550ti which should provide you with a big boost in performance but its hard to recommend parts if I don't know what kind of budget your on. You would need to upgrade your Power supply if you got the 550ti to 550 watt power supply if your current power supply is smaller than that.
Here's the price break down
Kingston 4GB of DDR2
$60
http://www.newegg.com/Product/Product.a ... ver-Memory
EVGA Nvidia 550Ti
http://www.newegg.com/Product/Product.a ... hics-Cards
$115
Power Supply
$65
http://www.newegg.com/Product/Product.a ... r-Supplies
Total upgrades $240
A new build would probably run about 600 bucks to about 800 bucks if you want a brand new entry level gaming PC
PostPosted: Fri Oct 19, 2012 1:09 pm
Take a deep breadth, toss it out to pasture...exhale, now build new!
CPU: Intel Core i3-2105, $122
MOBO: GIGABYTE GA-Z68AP-D3, $80
RAM1: Kingston HyperX 8GB (2x4) 1600, $30
RAM2: G.Skill 4GB (2x2) 1333, $20
GPU: Radeon HD 7750, $90
HDD: Seagate Barracuda 1.5TB, $70
PSU: CORSAIR CX430 V2 430W, $25
ODD: Samsung 22x DVD Burner Model SH-222, $14
Case: Fractal Design Core 3000, $39
$470 total for 8GB
$380 total for 8GB and iGPU
$460 total for 4GB
$370 total for 4GB and iGPU
PostPosted: Fri Oct 19, 2012 2:49 pm
Thanks so much for the input! I'm going to follow both ideas, I'll let my son use his allowance and part time job money for the upgrade and then build the new one for Christmas and surprise him if his grades hold up. Thanks again for your input.
PostPosted: Sat Oct 20, 2012 11:49 pm
kleinkinstein wrote:
Take a deep breadth, toss it out to pasture...exhale, now build new!...
Sorry but I concur. All of your parts are outdated and replacing any one will just bottleneck that newer part.
