It is currently Sat May 25, 2013 8:45 am
 Post subject: Computer Build
PostPosted: Tue Oct 16, 2012 6:23 pm
This will be my very first computer build. I have updated my two similar but different computer builds. One build is Intel and the other is Amd. Please post links to anything that is better for just the same money. Please tell me which build to product is for. Please tell me if everything is compatible. Thank you. Also tell me which build you would go with.
Intel Computer Build
Computer Case- Antec Nine Hundred -$100
http://www.newegg.com/Product/Product.a ... 6811129021
Processor -Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K - $220
http://www.newegg.com/Product/Product.a ... 6819115072
Motherboard - MSI Z77A-G45 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS - $110
http://www.newegg.com/Product/Product.a ... 6813130645
Memory - CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9 $85
http://www.newegg.com/Product/Product.a ... 6820233143
Hard Drive- Western Digital WD AV-GP WD10EURX 1TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $100
http://www.newegg.com/Product/Product.a ... 6822136941
Power Supply - COOLER MASTER eXtreme Power Plus RS-550-PCAR-E3 550W ATX12V V2.3 SLI Ready CrossFire Ready Power Supply - $60
http://www.newegg.com/Product/Product.a ... 6817171038
Dvd/Cd Drive - ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM - $20
http://www.newegg.com/Product/Product.a ... 6827135204
Video Card - ASUS EAH6670/DIS/1GD5 Radeon HD 6670 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card - $93
http://www.newegg.com/Product/Product.a ... 6814121442
Speakers - Logitech Z506 75 watts RMS 5.1 Surround Sound Speakers - $85
http://www.newegg.com/Product/Product.a ... 6836121044
Card Reader - SABRENT CRW-UINB 68-in-1 USB 2.0 Internal Card Reader w/ USB 2.0 Port supports SDHC/VISTA - $12
http://www.newegg.com/Product/Product.a ... 6820300608
Keyboard/Mice - $7 (Temp I'll b using a wireless when i get the extra money)
http://www.newegg.com/Product/ComboDeal ... bo.1072748
Monitor - Acer S201HLbd Black 20" 5ms LED-Backlight LCD monitor 250 cd/m2 ACM 12,000,000:1 (1000:1) - $100
http://www.newegg.com/Product/Product.a ... 6824009256
Total- $992
Amd Computer Build
Processor - AMD FX-6200 Zambezi 3.8GHz (4.1GHz Turbo) Socket AM3+ 125W Six-Core Desktop Processor FD6200FRGUBOX - $140
http://www.newegg.com/Product/Product.a ... 6819106010
Motherboard - GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard $110
http://www.newegg.com/Product/Product.a ... 6813128519
Total- $912
 Post subject: Re: Computer Build
PostPosted: Wed Oct 17, 2012 5:11 pm
I don't know what kind of tasks your going to be running on your PC but I would recommend a ATI 7770 http://www.newegg.com/Product/Product.a ... hics-Cards because its newer and only $30 more and would provide about a 30 to 40 percent increase in graphics performance. In your Intel build you should use a 3570K i5 instead because it'll provide you a 15% increase in performance and only costs $10 more and you can use the same mother board you have already chosen. Here's a Motherboard I would recommend for the 3570K from ASRock http://www.newegg.com/Product/Product.a ... therboards. You should consider getting an SSD too because it'll speed up your boot times. Here are a few you might want to consider http://www.newegg.com/Product/Product.a ... ternal-SSD http://www.newegg.com/Product/Product.a ... ternal-SSD
PostPosted: Wed Oct 17, 2012 5:54 pm
Welcome to building computers. I hope you have as much fun as I do.
Several things:
**As mentioned by the previous poster, you don't mention the intent of the computer; nor do you list a budget. Both of these need to be determined before you proceed. From your post, I'm guessing your budget is $1000 (since your two builds are about the same price) but you need to identify your budget and stick to it.
**AMD vs. Intel. Might as well get the 800lb gorilla out of the way. The majority of people will tell you to go with Intel. For the two CPUs you've selected, I can guarantee the Intel will beat the AMD in every test. Hands down. But that's why it's $80 more. At the same time, the 6200 is an excellent CPU. All things considered, that is probably the best Performance per $$ CPU AMD has right now. In fact, I would say Performance/$$, the 6200 would probably be top 10 CPUs right now - including Intel. So for the $80 savings you get with AMD, you can put that towards an SSD...or maybe a better GPU. I'm not saying buy AMD, but I am saying don't just discount them outright.
**16GB is a heck of a lot of RAM; 8GB should be fine. That will save you at least $40 that you can put towards something else, or your pocket.
**Thee 7770 is a very good card, but you should also consider the XFX 7750. It's about the same price as the 6670, better performance and a single slot so you don't lose one with overhang.
**As for the case, I don't know if aesthetics is the main reason you chose it, or if it was for some functionality, but I like the Antec Three Hundred Two. It's cheaper, professional looking, but still has a little personality. Again, another $40 saved.
**I haven't priced HDDs recently but $100 for 1TB seems high. Keep an eye out for a sale. Here's a Samsung 1TB F3 for $88 including shipping. You should be able to find a comparable HDD for $80 on sale, maybe $75. And make sure you need 1TB. Unless you have a large collection of music, movies or games, 500GB should be more than enough, getting you closer to $60.
Hope this helps.
PostPosted: Thu Oct 18, 2012 12:40 am
I'm going to beat this horse and say, yeah, what do you want to do with this build?
And maybe it's just me, but I'd consider a larger monitor than that 20-inch panel. A decent 23-inch panel at 1920 x 1080 resolution could be had for about $150.
To be a bigger jerk even, I'll suggest using http://www.pcpartpicker.com for its convenience.
PostPosted: Thu Oct 18, 2012 5:21 am
I'd first go Ivy instead of Sandy, unless you're an EOC'er...which I doubt if this is your maiden build. 3550K clocks much better than a 2500k and is only $180. With memory so damn cheap, I'm not going to discourage you from spending $60 for 16GB but go with 2x8GB DIMMS on a Z77, stay away from 4x4GB. If you have $100 to spend on storage, go bigger than 1TB. The 1.5TB Barracuda is $70 this week as is the 1TB Spinpoint or skip a few lunches this week and get the 3TB for $140 instead. 20" ain't much, add another 4" and go 1920x1200 -- it'll make a big BIG difference. And yes, follow the jackass, (err, I mean jerk) hindolio :) and use pcpartpicker so we can help you dial in your system a bit easier. Lastly, when you give us the details of your use case for this new rig, also provide us your budget?
PostPosted: Thu Oct 18, 2012 2:40 pm
Looking to spend around 1000 monitor and all. And why 2x8gb instead of 4x4
PostPosted: Fri Oct 19, 2012 12:20 pm
You'll want to have 2x8 because its about the same price as 4x4 and because 2x8 will let you upgrade in the future without having to replace any RAM sticks.
Users browsing this forum: Google [Bot] and 1 guest
