It is currently Fri Apr 17, 2015 10:14 pm
 Post subject: motherboard indecision!!!!
PostPosted: Tue Oct 16, 2012 5:08 am
okay, opinions, thoughts, recommendations everything on:
ASUS P9X79 Pro Motherboard vs Intel DX79SI LGA2011 Motherboard
i want a cutting edge gaming set up, you can also suggest other LGA2011 motherboards ill be running a Intel i7 3930k processor (:
please & thankyou
 Post subject: Re: motherboard indecision!!!!
PostPosted: Fri Oct 19, 2012 3:05 pm
I'd suggest the Asus P9X79 because it will offer you every feature you could possibly want in an X79 but both boards are excellent here's the P9X79 review. http://www.maximumpc.com/article/%5Bpri ... uxe_review If you don't care about price then go with the Asus board.
PostPosted: Fri Oct 19, 2012 3:54 pm
Yup, go Asus all-the-way for X79. Asus Sabertooth is a fine accoutrement of circuits. Stay far away from Intel, their boards are so friggin buggy and lacking in feature function and specs...it continuously makes me really wonder why they are actually in the mainboard biz! But also take a peek at the Extreme9 and if your budget and gaming acumen supports, the Extreme11. It is truly the one and only cutting edge board.
PostPosted: Wed Oct 24, 2012 4:33 am
thanks heaps guys!!! :D
