It is currently Wed Jun 19, 2013 6:54 pm
 Post subject: Help me decide which case would be a better buy?
PostPosted: Sun Oct 14, 2012 3:38 pm
Hi I need some help from you guy's deciding which case would be a better buy.
Could i get some input on which would be better?
Vulcan Micro ATX
APEVIA X-Jupiter Jr. S Type
I Currently own a Micro ATX motherboard
Thanks in advance guys!
 Post subject: Re: Help me decide which case would be a better buy?
PostPosted: Sun Oct 14, 2012 9:39 pm
Asking which case is a "better buy" is pretty subjective and thus complicated and ergo a difficult question to answer. Simple reply imho is the $30 case because:
- it's less than half the cost of the other case
- it's a mid tower so it's bigger and will probably offer better cooling and flexibility
- it is less conspicuous in form
Imho though, you might be served better with a newer case, as both of these are older styles (no USB 3.0, probably less efficient cooling). Must you decide between the two?
PostPosted: Mon Oct 15, 2012 7:46 am
Precisely what hindolio says above. And to add, have you graced you eyeballs on the offerings from Fractal Design, yet? I sense not.
