It is currently Sat May 25, 2013 2:04 am
 Post subject: Chassis Fan and Power Fan question.
PostPosted: Wed Oct 10, 2012 5:25 pm
Hi
This is my first time on this forum and my first PC build. I have an ASUS P8Z77-V LX LGA 1155 Intel Z77 Motherboard. My case is a Corsair Obsidian 550D mid-tower. This case came with 3 120mm fans, 2 in the front and 1 in the rear.
The fan headers on the Motherboard are labeled CPU Fan (4pin) - Chassis fan 1 (4pin) - Chassis fan 2 (4pin) - Power fan (3pin). I know where the CPU fan get connected to so my question is: What are considered the Chassis fans and what is the Power fan on my case?
Thank you
Andrew
 Post subject: Re: Chassis Fan and Power Fan question.
PostPosted: Thu Oct 11, 2012 3:09 pm
All the fans of your chassis (case) are Chassis fans. Where you plug what fan into is of your own knowledge. You have 3 fans...plug 'em in as you see fit.
I have several versions of the P8Z77-V board, but not the LX. You shouldn't have a "PWR" header these days. That is meant for PSU's that needed/had externally regulated fans so we can control them from the MOBO settings in the BIOS. I haven't seen that in a very long time. But you can still connect a case fan to it if you have one and still control it from the BIOS. Just know it's not your PSU and is so-and-so fan you hooked it to.
Quickly, they're just labels and act no differently. When you hook a fan to one of them, you'll know what fan it is to tweak in the BIOS. The CPU, yeah it'll be different and speaks for itself.
PostPosted: Fri Oct 12, 2012 6:08 am
Thank you Chumly for your help. I basically already hooked the fans up like you said just using common sense and everything worked out perfect. The fan wires of 2 of the 3 fans that came with the with the chassis just barely made it to the headers on my motherboard. I put fan wire extensions on them just to have some slack on those wires.
I already have 3 Dell PC's but I had to build a PC just to see if I could do it. I have to admit it was a small challenge but a lot of fun and I'll do it again when I have to.
Thanks again for your help
Andrew
Users browsing this forum: Google Adsense [Bot] and 6 guests
