It is currently Sun Jan 25, 2015 2:23 am
 Post subject: Where to get short SATA cables?
PostPosted: Sat Apr 02, 2005 12:02 am
I've got a case that has the hard drive cages on the bottom. I also have a motherboard with the SATA connectors near the bottom. The SATA cables that came with my mobo are quite long and I kind of have to coil them before I plug them in to keep them from interfering with anything else in the case, or blocking airflow. I am kind of a neat freak and hate the untidy way they look every time I see them through the side window.
Anyway, here's my question. Does anyone know of a place that sells short SATA cables? Or a custom cable place that will make them to a specified length? So far the shortest ones I can find are 12" and I'd really like some that are 8" or maybe even shorter. Thanks in advance for your help.
PostPosted: Sat Apr 02, 2005 12:47 am
believe the shortest ive seen around are the 10 inch uv http://www.2coolshopping.com/Merchant2/ ... 6-426-0001
PostPosted: Sun Apr 03, 2005 1:53 pm
New Egg doesn't have em'?
