It is currently Sat May 25, 2013 4:34 am
 Post subject: What mid-tower/tower cases accept a redundant power supply?
PostPosted: Fri Sep 14, 2012 12:51 pm
The redundant power supplies that are available do not fit in a standard PS2 power supply chassis.
Here is a redundant power supply example:
http://www.newegg.com/Product/Product.a ... 6817338098
Anyone know of a chassis that can hold this? Antecs did years ago, and the rack units do.
TIA
 Post subject: Re: What mid-tower/tower cases accept a redundant power supp
PostPosted: Fri Sep 14, 2012 1:02 pm
These are your only options for something resembling a tower.
Otherwise you'll have to make due with a rack mount chassis.
PostPosted: Sun Sep 23, 2012 6:48 am
Can't find any pedestal cases to hold that kind of a power supply, but Logisys makes a nice rack-mount inexpensive case for the job.
PostPosted: Sun Sep 23, 2012 9:07 am
Coolermaster's OG Stacker will (It's called the 810 after the next Stackers were released), and it even comes with a PSU jumper. It's not 'redundant' exactly, but is dual PSU capable. To have redundant PSU's I believe you must have switching PSU's and makes all the difference. In a dual PSU build, if one fails the other should be large enough to hold up the load, thus it's close enough to me. In a true redundant system, one is offline until the primary fails and then the standby comes online. In a dual, they'll be working in parallel 24/7.
Which, BTW, will help efficiency a heck of a lot. It's a dated thread, but I show this in the modders workshop back in 2005 or so. They're legacy items, but can find them new in the box still on eBay. Still my favorite tower produced to this date.
PostPosted: Mon Sep 24, 2012 11:20 am
I really like this combo:
Here's the rack-mount chassis:
http://www.logisyscomputer.com/viewsku. ... K&DID=C001
Here's the redundant power supply (80+ Certified):
http://athenapower.com/product/power-su ... rp4atx6508
Here are the rails for mounting in a rack:
http://www.logisyscomputer.com/viewsku. ... 0&DID=C001
