It is currently Mon Jan 26, 2015 9:47 am
 Post subject: need advice on this monitor
PostPosted: Tue Mar 29, 2005 9:56 pm
I'm lookin at buying a combo kit and in this kit it comes with 2 bfg 6800 gt oc video cards and this princeton lcd monitor and i need some input from people in whether the monitor is good and worth the 200 extra or should i save and get a better. heres the link http://www.newegg.com/app/viewProductDe ... 011&depa=1 this is the one included
PostPosted: Sun Apr 03, 2005 3:53 am
Folding Momerator
Folding Momerator
The monitor looks like it got decent reviews, which is important. It also has DVI & analog, so that's a plus. I would see if I could find it at a local brick & mortar store. Do you have a link to the actual deal page? Depending on what the actual cost, is it really free? If it is, then hey, why not?
Buying a monitor isn't easy. When I bought this 17 inch Sony with Xbright technology, I wasn't looking to spend $300+, but after seeing it in person, I had to have it, it is awesome! If you have a Comp USA, Circuit City or Best Buy, go have a look at it. It's really a sweet monitor, looks like it has glass but doesn't. I hear there are these Acers that have the same technolgy but it's called something different.
So far the Acer AL1931 is the only one I've been able to find.
If you are in fact spending money on that monitor, I'd go with the
SONY® 17" HS-Series Computer Display (SDMHS75B) - $309.99 after rebates and at Sony SDM-HS75P/B suggested retail after rebates- $ 399.99
PostPosted: Sun Apr 03, 2005 5:47 pm
the princeton monitor looks good in appearance and specs.
PostPosted: Sun Apr 03, 2005 10:32 pm
Quote:
Response Time: 25ms
umm...that isn't so good if you plan on gaming with this thing
PostPosted: Sun Apr 03, 2005 11:47 pm
ya they stopped the deal so i decided not to go with it. but as far as monitors like 3 months are i build my comp at the end of this month i'm looking at buying this lg monitor. http://www.newegg.com/app/ViewProductDe ... 034&depa=0
i like lg i see this series at bestbuy and it too has the glass look to it and its stupid clean and would match my black coolermaster wavemaster case well.
PostPosted: Mon Apr 04, 2005 6:17 am
The LG looks good. It has the same response time as the Dell 2005FPW 20.1-inch. Actually, right now you can get the Dell LCD for 561.75.
Go Here:
http://accessories.us.dell.com/sna/ProductDetail.aspx?TabPage=producthighlights&sku=320-4111&category_id=4009&c=us&l=en&cs=19
