It is currently Sun Apr 19, 2015 4:51 pm
 Post subject: Can you explain the DDR2 711 Native Support part of this MOB
PostPosted: Tue Mar 29, 2005 8:07 pm
Although Intel's 925XE chipsets claimed to only support DDR2 400/533, ASUS engineers successfully unleashed their true potential. This model offers native DDR2 711, eliminating the bottleneck when overclocking both the CPU and memory. With current processors supporting 1066MHz FSB, ASUS motherboards, the only solutions with native DDR2 711, will provide superior performance for the most demanding applications.
FSB/MEM (freq.)
ASUS
Other brands
1066/711 (Native)
V
does this mean that you could purchase 700 series memory instead of 533?
I have already ordered this Asus P5AD2 MOBO along with the P4 650 CPU. I am now looking at memory to go with it. I will be looking at 2-1gb sticks. Whats your opinion? are they sayin that you can overclock the 533's to get the 711. I found this looking for memory,
Manufacturer: PDP / Patriot
Speed: DDR2-700(PC2-5600)
Type: 240-Pin DDR2 SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 4-3-3-12(DDR2 700), 4-3-3-10(DDR2 667), 3-2-2-4(DDR2 533)
Support Voltage: 1.8V
Bandwidth: 5.6GB/s
Organization: 128M x 64 -Bit
PostPosted: Thu Mar 31, 2005 9:50 am
Bump, still looking for clues.
PostPosted: Thu Mar 31, 2005 10:43 am
I have that same board only its the 925X version and has support for DDR2/600... can anyone answer this question?
PostPosted: Thu Mar 31, 2005 12:10 pm
2 theorys, one its running on a diffrent divider (200 mhz fsb and 266 mhz ddr2 ram) so say its running at 200 mhz fsb and 300 mhz ram that would be a 2:3 divider im guessin so for every 2 clocks of the fsb the ram has 3 clocks (im not sure how all that works but it will be async so it mite not be as efficent)
ddr2 711 i have no clue about well i dont realy have a clue about running at ddr2 600 but my guess is, its a hack that asus does to enable you to run your memory faster at a stock processor speed so u can get the full value out of higher rated ram
PostPosted: Fri Apr 01, 2005 6:41 pm
Bump again, anyone got any ideas. I wondering which ram to get with this mobo and chipset.
