It is currently Thu Mar 26, 2015 11:30 am
 Post subject: Overclocking an MSI 6600GT AGP
PostPosted: Mon Mar 28, 2005 7:01 pm
I would like to overclock my video card, but have some questions before I completely mess things up. First question: With the MSI 6600GT, you can set the 2D and 3D core speeds, as well as the memory. If I am OC'ing this card, do I have to OC both 2D and 3D clocks, as well as the memory? This leads me to the next question, if I OC the 3D Clock, do I have to OC the 2D as well? Second Question: what are the temps that my card should be at, and how do I check them? Third Question: Should I use the software that came with the card, or as Brendan suggested, Rivatuner?
PostPosted: Wed Mar 30, 2005 1:53 pm
Anyone?
PostPosted: Thu Mar 31, 2005 12:38 pm
Dont worry about the 2D Core... 3D and memory only, keep goin' up 5-10MHz at a time till you see atifacts (out of place or random objects) on the screen. Do the same for the memory.
PostPosted: Thu Mar 31, 2005 9:29 pm
thanks
