It is currently Fri Mar 06, 2015 1:07 am
 Post subject: Printer
PostPosted: Thu Mar 24, 2005 6:04 pm
My parents had an epson c82 which clogged for not being used for a little while. I looked up online the recommended way to fix and still can't get it working. Seems there was a design flaw that this is common problem.
So I'm trying to recommend them one of those basic samsung lasers since I'm guessing they won't dry out and not work as easily. That or get a canon since you can replace the print head or an HP since the ink carts contain them.
Which do you think? Preferably under $100 (samsung is $80 after rebate).
PostPosted: Fri Mar 25, 2005 11:30 am
If all I wanted to print was text i would get a cheap($150) laser but I would stay away from any HP inkjet if I was gonna get a inkjet it would probably a cannon
PostPosted: Fri Mar 25, 2005 12:21 pm
I wholeheartedly suggest a laser printer if only because it's a much more cost-effective solution, in the long-term, if you're printing either color or just monochrome. My family works off of laser printers because it's so much cheaper.
