It is currently Sun May 03, 2015 7:54 am
 Post subject: Can anyone help me find...?
PostPosted: Wed Mar 23, 2005 10:54 pm
King of All Voodoo2 Cards
An ATX Desktop or Tower case that ships with an Intel Marl / Aurora backplate? I've been looking around but haven't had much luck. I even emailed Antec to see if they'd custom machine one for one of their newer cases but no such luck.
Anyway, I'm trying to bring back my first SMP system from the dead.
PostPosted: Thu Mar 24, 2005 2:25 am
Celeron
Celeron
First result that I found with the google search "Intel Marl / Aurora backplate". (No offense :P) 5ยข O_O
I don't know if that's exactly what you're looking for so, excuse the n00bness here. :)
PostPosted: Thu Mar 24, 2005 5:31 am
Here is one that specifically names the aurora marl plate. (ATX 2.1)
AFAIK you should be able to just switch this plate with the one that comes with the case you already have or plan on getting.
PostPosted: Thu Mar 24, 2005 6:32 am
I already bought two of those a few weeks ago from compgeeks, however they don't seem to fit any modern cases.
A sales rep at CompUSA and I went down their entire case line looking for one that would fit the backplate but no dice.
So I was hoping to find a case that came with one.
PostPosted: Thu Mar 24, 2005 1:35 pm
I think you'll likely be out of luck, I would get an old case and dremel out and do it that way.
PostPosted: Fri Mar 25, 2005 9:22 am
I think I'm going to get a new case and find a way to glue/tape/solder one of the backplates I bought into it.
