It is currently Sat Apr 25, 2015 11:07 am
 Post subject: Unlocking multipliers
PostPosted: Wed Mar 23, 2005 6:12 pm
Location: Working an a nuke and browsing the fourms at the same time.
At risk of sounding like a newbee how if it is possible do you unlock a
Pentum 4s multipiers?
PostPosted: Wed Mar 23, 2005 6:21 pm
Smithfield*
Smithfield*
there is jsut one board you can do it with. an asus i believe. but if you buy an AMD FX series proc. they let you play around with multipliers all you want.
PostPosted: Wed Mar 23, 2005 6:24 pm
I not really worred about damaging my processor is there a way to do it by physicaly modifying my cpu.
PostPosted: Wed Mar 23, 2005 6:28 pm
Smithfield*
Smithfield*
HHHHHHAAAAHAHAHAHAHHAHAHAHAHAHAHAH no
PostPosted: Wed Mar 23, 2005 8:43 pm
the ONLY way to get a P4 with an unlocked multi is to find someone willing to sell an engineering sample(ES), sometimes you can find them over at [H] or at xtremesystems.org
PostPosted: Thu Mar 24, 2005 9:31 am
High end ASUS boards (P5AD2(-E) Premium) let you LOWER the multiplier, but not raise it.
PostPosted: Thu Mar 24, 2005 10:20 pm
dont know if this helps but........
http://www6.tomshardware.com/motherboard/20040916/
PostPosted: Fri Mar 25, 2005 8:52 am
Good luck buddy....
