It is currently Tue Jan 27, 2015 8:31 pm
 Post subject: Running RAM at lower CAS timings Than specified
PostPosted: Wed Mar 23, 2005 1:12 pm
What happens if you run your RAM at lower timings than the RAM is specified at?
PostPosted: Wed Mar 23, 2005 1:19 pm
Celeron
Celeron
If it's lower than it can ever handle, you'll suffer instability.
PostPosted: Wed Mar 23, 2005 1:25 pm
Contributing Writer
Contributing Writer
And if it can handle it, you'll receive better performance, albiet not likely noticeable outside of benchmarking.
PostPosted: Wed Mar 23, 2005 1:27 pm
Don't bother, the gains are tiny if they exist.
Hm... well Im not having a problem yet. The Kingstons are rated at 3-3-3. But i have it at 2-2-3.
PostPosted: Thu Mar 24, 2005 4:00 am
up the voltage!!!
PostPosted: Thu Mar 24, 2005 7:46 am
Contributing Writer
Contributing Writer
If it will run lower without stability problems or churning out errors, then you might as well. While in and of itself the benefits won't really be noticeable, it's another part of your system that you can optimize.
