It is currently Tue Mar 03, 2015 8:30 pm
 Post subject: Thermal Grease on Chipset?
PostPosted: Wed Mar 23, 2005 12:02 am
I have a Soltek Mobo and am wondering if you are capable of putting thermal grease on the chipset? Not the main cpu but the actual chipset on the mobo? Can you just take the stock heatsink without fan off and apply thermal paste? Will this help to do anything? Please let me know one way or the other. This board uses nforce3.
PostPosted: Wed Mar 23, 2005 3:42 am
Celeron
Celeron
If the board has been running fine for you, then there's no point in doing this. Don't fix something that isn't broken. :P
Also, since the chipset isn't too big, the thermal paste might ooze off onto the motherboard and possibly wreck it if you add too much.
PostPosted: Wed Mar 23, 2005 4:29 pm
My old motherboard had a noisy fan so i took it off in an attempt to replace it, there was already thermal paste between the 2 and it ripped a bit of the chipset off and i had to get a new mobo, i wont do that again.
PostPosted: Wed Mar 23, 2005 8:33 pm
You two are life savers. I thank you for those replies because i almost did it tonight but decided to check back here first. Glad i didn't douche that up :) Thanks guys.
-Feldman
