It is currently Thu Mar 26, 2015 6:17 pm
 Post subject: Dell Ram
PostPosted: Mon Mar 21, 2005 2:58 pm
My P-4 Dell currently has 256MB of PC800 RDRAM. Can I replace it with anoher type of memory?
Thanks
PostPosted: Mon Mar 21, 2005 3:10 pm
Chief Surgeon
Chief Surgeon
You can only use RDRAM Memory. Depending on the motherboard and processor, you could use PC600, PC700 or PC800 RIMM modules. I would gather since you already have PC800, you would need to add more PC800 modules.
RAMBUS RDRAM Memory is quite expensive, and you typically will have to use Dell's recommended Supplier. At CompUSA, our PNY and Centon RIMM Modules do NOT work with Dell systems bearing RIMM Slots. Crucial, Micron and Kingston all make quality memory.
SC64
PostPosted: Mon Mar 21, 2005 3:36 pm
I have the same problem. I am building a new PC instead...
PostPosted: Mon Mar 21, 2005 3:45 pm
Team Member/ Ex-Team Member/ Team Member
Dell used Samsung memory in mine. Get the 40ns for pc800 rdram. If you get the 45ns it might not work depending on which Dell your running. The 40ns will work.
