It is currently Mon Mar 30, 2015 5:18 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: 6800NU at GT speed....
PostPosted: Mon Mar 21, 2005 2:09 pm
That's right: stock cooling, 16/6 using RivaTuner command line, 400/1000 with PowerStrip.
PostPosted: Mon Mar 21, 2005 2:10 pm
Celeron
Celeron
Grr... I just saw your other thread and was about to reply:
Sovereign wrote:
If I unlock my 6800NU, I find that I get little blue lines down my screen (outside of games). It doesn't make anything unreadable, but is this OK? Or am I damaging my card/risking my whole screen turning blue?
EDIT: I bumped my clock speeds higher, up to 810MHz mem, 400MHz core, and the artifacts went away. Weird or what?
Damn, you're encroaching GT/U specs there! Very cool!
Check the temperatures of your card... #2 priority after checking artifacts.
Do the artifacts appear in game?
Edit: I literally find it unbelievable that your card reached 1GHz mem.
PostPosted: Mon Mar 21, 2005 2:29 pm
62C idle whether I'm at 350/710 "safety" mode (not playing games) or whether I'm at GT speeds. Yes, I plan to get a new cooler. Must...get...new...cooler....MASSIVE artifacts in AquaMark and Doom III. I mean D3 looked like a disco scene....
PostPosted: Mon Mar 21, 2005 10:01 pm
Celeron
Celeron
LOL Good luck!
PostPosted: Tue Mar 22, 2005 1:44 pm
UPDATE: AquaMark 3 - At 400/850 16/6 no artifacts, total score 49634, CPU 6392 and GFX 8112. This is unregistered AM default, which is 1024x768 @ 32, No AA and 4xAF, detail Very High.
PostPosted: Tue Mar 22, 2005 1:49 pm
UPDATE 2: Same settings as before except 400/900. Still good.
PostPosted: Tue Mar 22, 2005 2:34 pm
Celeron
Celeron
Bench 3Dmark05...
PostPosted: Tue Mar 22, 2005 2:47 pm
Check HERE for what happens at 1GHz memory (scroll down, it's AquaMark)...
PostPosted: Tue Mar 22, 2005 2:51 pm
Celeron
Celeron
Ouch.
Again, try 3DMark05 at 400/900. It'll stress it out like hell and if it shows up with artifacts, you know it's a bad OC.
PostPosted: Tue Mar 22, 2005 4:33 pm
It runs at that speed (400/900) with no issues whatsoever.
PostPosted: Tue Mar 22, 2005 4:35 pm
Smithfield*
Smithfield*
what brand? leadtek i'm guessing or one with aftermarket cooling?
PostPosted: Wed Mar 23, 2005 3:54 pm
No BFG. Still on stock.
 Post subject: cool
PostPosted: Wed Mar 23, 2005 11:32 pm
how about this guys
AMD64 3200+
512 DDR 3200 Crucial Ballistix
BFG 6800 GT OC 256 GDDR3
Asus A8V mobo
overclocked the vid card to 425/1100
the hottest it got was 54c, and the temp of ambient was 32c
aquamark3d got a score of 65745
3dmark05 got a score of 5625
i dont think thats to shabby eh?
PostPosted: Thu Mar 24, 2005 12:07 am
wait... you only get 49000K with that am i missing something?
with my radeon 9800 Pro flashed to a XT and @ 435 core and 385/770 mem with a mobile 2500+ @ 2.4Ghz 1 GB PC3200 Corsair XMS, i get 48,000+
PostPosted: Thu Mar 24, 2005 2:44 am
Celeron
Celeron
Yeah, that's why I told him to bench 3DMark05.
 Post subject: k?
PostPosted: Thu Mar 24, 2005 6:32 pm
well i guess you guys didnt look at mine? ..well good luck guys, see ya
 Post subject: Re: k?
PostPosted: Thu Mar 24, 2005 6:33 pm
Celeron
Celeron
Yes, I saw yours. Yes, you made a good point. We agree with your point. Happy? :P
PostPosted: Thu Mar 24, 2005 8:01 pm
What settings are you using for your benches, toidiochysp?
And how 'bout this: FSAA at Quality Level 4 (don't know what that is, it's AquaMark's setting), AF 16x @ 1024x768 custom test w/sound on...Avg FPS was 37, high ~52FPS, low ~27FPS.
PostPosted: Thu Mar 24, 2005 8:12 pm
just normal Aquamark 3 same as you
PostPosted: Thu Mar 24, 2005 8:15 pm
OK new test: 425/900 got about 47k, so the core was too fast....trying 390/900....
UPDATE: At these settings, got 48k, temp is 59C?!??!!?!?!? (Had 66C just idle after start....)
UPDATE 2: 390/925 got 48k....any ideas on how to increase?
UPDATE 3: 440/925 48k again....
UPDATE 4: 400/940 48k again, small artifacts in "Large-Scale Vegetation rendering"
