It is currently Fri Jan 30, 2015 2:20 pm
 Post subject: Cheap Linux box??
PostPosted: Tue Jul 03, 2012 4:47 am
Hey all - wondering if anyone knew of a real cheap (less than $80) box I can throw linux on. I do not need anything heavy whatsoever, I want to run a small version of Linux and a couple utilities.
BTW - no to Raspberry Pi Since it will not run the utility I want. =)
Thanks!
 Post subject: Re: Cheap Linux box??
PostPosted: Tue Jul 03, 2012 5:00 am
$80? Allow me to save you $50 with this yard sale unit.
PostPosted: Thu Jul 05, 2012 6:47 pm
Hi there
I plan on getting hold of one of these which I found while researching stuff for the Raspberry PI which I may never get hold of waiting waiting waiting.........
The MK802 supposedly will boot any Standard Linux OS - I will be running one of the PuppyLinux Flavours:
http://puppylinux.org/main/Overview%20a ... tarted.htm flavour not sure which yet with XBMC on it or maybe just straight XBMC.
Go have a look see what you think, there is a 512ram one as well for around $60 bucks.
http://www.geek.com/articles/chips/74-m ... -20120517/
Re the Raspberry there is going to be a specific Puppy Linux dedicated to this so it may or may not end up amazing.
http://puppylinux.org/wikka/Puppi
There is also this reviews and info for the CX-01 around $53
http://liliputing.com/2012/06/cx-01-53- ... stick.html
MK802 newer model coming with better specs.
http://liliputing.com/tag/mk802
Hope this helps
Cheers
KazzaMozz
