It is currently Tue May 21, 2013 8:48 pm
 Post subject: Mid range PC hopefully built to last. Advice on parts please
PostPosted: Fri May 25, 2012 11:41 am
Approximate Purchase Date: Month or 2
Budget Range: £600-700
System Usage from Most to Least Important: Gaming
Parts Not Required: Keyboard mouse screen
Preferred Website(s) for Parts: amazon
Country: UK
Parts Preferences: by brand or type Geforce card, Intel processor
Overclocking: Yes - probably just CPU
SLI or Crossfire: Yes, but later as an upgrade path
Monitor Resolution: 1920x1080
Hey. I've complied a list of parts that seem good to me, was wondering if anyone has any ideas to decrease cost and retain performance, or to boost performance with minimal costs. Planning on running a 560 TI now until I have the money and inclination to upgrade, then buying another 560 and SLIing in the future at some point. Planning to overclock the i5 to at least 4ghz, maybe more, hence the aftermarket cooler.
Thoughts appreciated! Also please say if I've left any major components out, but don't think I have. And do you think one 560 now and one later is a viable upgrade path?
List link http://www.amazon.co.uk/registry/wishli ... =1&reveal=
G-Skill 8GBXL Ripjaws X for Intel Sandybridge Platforms DDR3 PC12800 1600MHz 8GB Kit
by G-Skill
4.7 out of 5 stars (31)
£39.74
Seagate ST31000524AS 3.5 inch Barracuda 1TB GB 7200rpm SATA Drive with 32MB Buffer
by Seagate
3.7 out of 5 stars (25)
£64.68
MSI 1155 Intel P67 4xDDR3 SLI Crossfire USB3.0 ATX Motherboard
by MSI
4.4 out of 5 stars (5)
£83.99
Asus 1GB GeForce GTX 560TI DirectCUII PCI-E Graphics Card
by Asus
4.8 out of 5 stars (63)
£167.99
Sony 24x Internal DVD Rewriter - Black
by Sony
4.2 out of 5 stars (19)
£12.81
In stock.Offered by Amazon.co.uk
Antec Three Hundred Midi Case
by Antec
4.5 out of 5 stars (41)
£42.47
Corsair CMPSU-750TXV2UK​ Enthusiast Series TX750 V2 High Performance 750W Power Supply
by Corsair
4.5 out of 5 stars (15)
£83.98
Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler
by Arctic Cooling
4.1 out of 5 stars (204)
£16.19
Intel Sandybridge i5-2500K Unlocked Core i5 Quad-Core Processor (3.30GHz, 6MB Cache, Socket 1155)
by Intel
4.9 out of 5 stars (61)
£156.20
Currently stands at £667.96
 Post subject: Re: Mid range PC hopefully built to last. Advice on parts pl
PostPosted: Sat May 26, 2012 5:00 pm
Welcome to the forums! And good luck with your build.
While you have a decent build, please realize many of the components are over a year old. It should be a great computer for a couple years to come, but you may want to look at some of the more recent CPUs/mobos to see if you can find something similar in your price range.
As for your components:
If you want longevity, lood at the Antec Three Hundred Two case, rather than the Three Hundred. It's essentially the same case, but slightly updated and includes USB 3.0 front panel inputs.
P67 is a good motherboard, but check to see if there are any Z68 mobos that fall within your price range.
Also, I'm not sure if your "that" gung-ho on SLI. If you are, then stick to looking for a mobo that supports it; otherwise, consider getting a non-SLI board with the understanding that you upgrade the GPU rather than buy a second one of the same kind. It might allow you to find a cheaper motherboard which allows you to put the money elsewhere in your build.
Hope this helps.
PostPosted: Sun May 27, 2012 5:47 pm
The thing with upgrading to SLI and Crossfire in the future is that it has to be a near-term goal, within a year. It can't be a "two years down the road" thing. By the time a year or so passes, a graphics card that can perform as good, if not better, than your current one in SLI should be available for a bit more than what you would be paying to find a second card. And yes, hardware prices don't drop very much after a certain point. You can find GTX 280s that go for $250-$300, even though it performs like a $120-$150 card now.
