It is currently Fri May 24, 2013 6:41 am
 Post subject: will these parts make a good pc?
PostPosted: Sat May 19, 2012 4:15 am
im new to pc building and i want to know if these parts will make a good PC for video but manly gaming
ive never built a pc before but i have been doing alot of research into parts and how to build it
im thinking of overclocking the CPU aswell
i want to know if these parts will make a good PC or if there will be some bottlenecks
here are the parts i have chosen:
ASUS Rampage IV Formula with Battlefield 3
Corsair Vengeance Red CMZ16GX3M4X1866C9R 16GB (4x4GB) DDR3
Western Digital Caviar Black 2TB WD2002FAEX
Intel 520 Series 120GB SSD
Intel Core i7 3930K
Corsair Hydro Series H100 CPU Cooler
Corsair Graphite 600T Special Edition White Case
Pioneer BDR-207DBK Blu-Ray Disc Writer OEM
Microsoft Windows 7 Ultimate 64bit with SP1 OEM
BitFenix Alchemy Connect 30cm Red LED Strip
Corsair TX-850 V2 Power Supply
ASUS GeForce GTX 670 DirectCU II TOP
Corsair Vengeance M60 FPS Laser Gaming Mouse
Corsair Vengeance K60 FPS Gaming Keyboard
ASUS VE247H 23.6in Widescreen LED Monitor
20Pin Socket to Dual USB 3.0
totals AU$3343
https://www.pccasegear.com/index.php?ma ... wish_lists
 Post subject: Re: will these parts make a good pc?
PostPosted: Wed May 23, 2012 12:11 am
Team Member*
Team Member*
The X79 platform will almost always make a good PC and if you have the money go for it. You might be able to save a little on a few other parts but the PC will still be good none the less.
PostPosted: Tue Jun 12, 2012 2:33 am
what parts would us save on?
PostPosted: Tue Jun 12, 2012 12:34 pm
The X79 system itself. Getting a Z77 and an Ivy Bridge system will offset at least $300-$400.
PostPosted: Tue Jun 12, 2012 2:03 pm
Do you have a set budget you are looking to stay within? I see you are spending $3300+, but you could easily drop that a couple hundred dollars if you wanted.
You could also get a lot more performance out of your system if you swapped the i7-3930K for say an i7-3770k or i5-3570K and your MOBO for a Z77 MOBO, then added another GTX 670, and you would be at around the same price point.
You could also drop your RAM to 8GB to save about $50(broken record saying around here) because that's all you will ever need for gaming.
If you could give us a budget you want to keep I think we can suggest a really nice setup that gives you a lot more bang for your buck then what you have selected so far.
PostPosted: Thu Jun 14, 2012 1:02 am
Team Member*
Team Member*
Here is the reply:
green_man_5 wrote:
i don't have a set budget but i don't want to spend any more than the AU$3300 by switching the 3930k with the 3770k I save $200 and form the rampage 4 to the z77 sabertooth i save $100 but is it worth losing those 2 extra cores and the other 2011 socket goodies to save $300? since half of the reason for this pc is for video editing (the other is gaming) i would rather spend the $50 and get more speed with editing, but i know most games don't use 8GB but doubling the ram for $50 isn't that bad i would say 60% of the time gaming 20% video editing and the rest is just general stuff that is not very intensive eg web browsing etc. as I said before i don't have a set budget but around AU$2500 for the tower (CPU, gpu, case etc.) and no more than $500 for the other stuff (eg mouse keybored and monitor) i think in the future i will be adding to this rig as well so i would like it to be good for a long time. thinking of adding another gpu to do SLI and adding another monitor or 2
Users browsing this forum: Google Adsense [Bot] and 4 guests
