It is currently Tue May 21, 2013 4:41 am
 Post subject: first gaming pc build... your thoughts please
PostPosted: Wed May 16, 2012 10:12 pm
I have a $2000 limit and I am mainly using this as a gaming pc with dual monitors. eventually i will be using dual graphics and might possibly be running 3 screens instead of 2.
[ VideoCard ] EVGA GeForce GTX 670 4GB Superclocked+ w/Backplate - ($489.99)
[ processor cooling ] Corsair CWCH80 Hydro H80 CPU Liquid Cooler - 120mm Fan, LGA775, LGA1155, LGA1156, LGA1366, LGA 2011, AM2, AM3 - ($102.99)
[ OS SSD] OCZ AGT3-25SAT3-60G Agility 3 Series Solid State Drive - 60GB, 2.5" SATA III, 6Gbps {for OS} - ($59.99)
[case] Corsair CC600TM Graphite Series 600T Mid Tower Case - ATX, M-ATX, 4x Ext 5.25", 6x Int 3.5", 2x 200mm White LED Fans, 1x 120mm Fan, 4x USB 2.0 Port, 1x USB 3.0 Port, 1x IEEE1394 Front Ports, Mesh Side - ($159.99)
[Power Supply] Cooler Master RSA00-AMBAJ3-US Silent Pro M 1000W Power Supply - ATX, Modular, 1000 Watt, 80+ Bronze Certified, SLI, 135mm Ultra Silent Fan - ($169.99)
[HDD] Seagate ST2000DL003 Barracuda Green 2TB Hard Drive - 2TB, 5900 RPM, 64MB, SATA-6Gb/s - ($99.99)
[ Motherboard] ASUS P8P67 Pro Intel P67 Motherboard - ATX, Socket H2 (LGA 1155), Intel P67 Express, 2200MHz DDR3 (O.C.), Gigabit LAN, 8-Channel Audio, SATA 6.0 Gb/s, SuperSpeed USB 3.0, SLI/CrossFireX, refurbished - ($170.96)
[ processor] Intel Core i5-3570K BX806237i53570K Processor - Quad Core, 6MB L3 Cache, 3.40GHz (3.80GHz Max Turbo), Socket H2 (LGA1155), 77W, Fan, Unlocked, Retail ($239.99)
first pc build :D
 Post subject: Re: first gaming pc build... your thoughts please
PostPosted: Thu May 17, 2012 10:26 am
I'm going to apologize up front if I sound rude...
  • Next time, post the component names themselves with the URL. Price is also a nice plus. The URL is just there for verification. Nobody wants to click on a half dozen links.
  • The motherboard is not compatible with the processor. The motherboard is a socket LGA2011 board. The processor is meant for a socket LGA1155 board. Either find a compatible motherboard, or find a compatible processor.
  • You don't need water cooling unless you plan on overclocking.
  • You don't have a video card, unless you really want to play on Intel's integrated graphics.
  • You don't need 16GB of RAM, 8GB is fine.
  • The power supply is overkill. If you're going with a single video card setup and don't plan on adding another, you'll need 500W-600W tops. If you want to do SLI/Crossfire, add 150W to each video card you include
PostPosted: Sat May 19, 2012 7:56 pm
yea i fixed the post. i changed the motherboard, but my friend says to get the sabertooth... i think this might be way too much so i countered with this :
ASUS P8Z68-V/GEN3 Intel Z68 Motherboard - ATX, Intel Z68 Express, Socket H2 (LGA1155), 2200MHz DDR3 (O.C.), SATA 6.0 Gb/s, RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCIe 3.0, CrossFireX/SLI, Bluetooth - ($169.99)
i do apoligize for my ignorance in making pc's and the posting style of this website.
but i really would like you opinions
PostPosted: Sun May 20, 2012 10:19 pm
Don't get the video card, you're $10 from a stock GTX 680 at that point (and I don't even know why EVGA is bothering...). I'd recommend the Superclocked version, which runs for about $430, but I don't know if the almost 10% increase in price delivers almost 10% increase in performance.
The power supply is still overkill. And despite my initial estimates, get something that floats around 700W-750W.
You also forgot to add memory.
